I am thinking the weight capacity is roughly 230 lbs if I am not mistaken. That weight is like any other manufacturer weight as you mentioned above about the Honda Rancher. Just like any 1/2 ton pickup - total weight capacity is 1000lbs - so basically put 3 big guys in the cab weighing 300 pounds each and according to the manufacturer - you can only haul 100 pounds in the bed. I regularly ride with my wife and lots of gear on my 250ES Big red - and we probably have 450 pounds of capacity - it does just fine.
If you are looking for an "Actual" number - you won't find one - it would be like Ford saying - you can "Actually" haul 4000 pounds in you 1/2 ton pickup.
