Results 1 to 15 of 17
Thread: wanting to build an atc for extreme mud help!
    Mar 2011
    belleview, florida
    29
    this is my first post, but ive been a reader for a while and found the best info on this site, so im wanting to build a threewheeler up for mud i know where a big red 200 is with hi and low shaft drive, is the low end on this bike enough to pull really big tires in low?or should i try finding an 82-83 200 thats chain drive so i can gear it down, and could i gear it down enough to turn like 29.5 outlaws or 31 BACKS maybe?any help is greatly apreciated!
    Mar 2011
    belleview, florida
    29
    come on nobody has any input???
    Worcester, MA
    1,117
    Another member is working on the same thing, he made an 8 tooth front sprocket for 27" tires but needs it lower with a 200 motor.
    Try a big red 250es, or 250sx, hopefully 86 or 87 as they seal better. Then buy a 54% reduction, it will cost you a good amount of money for the machining work (think $150) and then you'll need the parts.
    Apr 2010
    slaughter, la
    59
    i am researching a gear reduction for my 185s now. the low range on the br 200 is low but i have never put that big of tires on one to see if it could spin them. any gear reduction will require machine work. i would say stay away from the chain because while riding in the mud you take a chance on a rock getting in between the chain and sprocket. it doesn't happen often to me but it still happens. the rock doesnt cause much damage. the chain however may come off and get wedged between the front sprocket and the case. not good. try the br 200 and see. if it doesn't spin them, then hopefully i have mastered the gear reduction though the clutches with my bike. as far as clutches go, they are the same between our two bikes. pm me in a few weeks to how it is going. i ordering parts today to play with so i can't get started untill they come in.
    Apr 2010
    slaughter, la
    59
    keep in mind that you might want to consider a snorkle for the deep stuff. look at mine if you need some ideas
    Nov 2010
    Oshawa, On, Canada
    2,123
    A 250es would be fine in SL with 31's.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Mar 2011
    belleview, florida
    29
    well i just got a descent lookin 200m because i think with the right sprockets from sidewinder ill have no worries, as for the 200 shaft drive im gonna work on buying that to build next.ill post a picture soon as i figure it out
    Mar 2011
    belleview, florida
    29
    http://mediamail.boostmobile.com/mmp...&clampsize=320
    sorry i dont know how to post pics just the link, what yall think was it worth 400?starts right up electric start no smoke an rides out!
    Oct 2007
    Minneapolis mn
    4,067
    Do a search for Skiffys BR, he is running 30" Backs, and Mondexbrute got a sweet BR running 28's I believe...
    Mar 2011
    belleview, florida
    29
    yeah i seen both them on highlifter the one on thirtys doesnt do to bad but what i like about mine is i can gear it for them!
    ontario
    1,131
    that 200m is in really good shape I would go for it and for $400 thats a steal, I payed $300 for one that had not ran in 10 years and was cracked up. I want to see how it works out with the 30's
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    Worcester, MA
    1,117
    If you want the best mudder out there:
    Big Red 250es or SX.
    TRX 300 motor, Big Bore Kit, the new 54% Gear Reduction, 4 valve head swap or just a 459 cam, big red timing chain, carb swap from trx 300 or 300ex, clutch kit.
    Then do a fender lift or extend the rear end to clear giant tires. That will be a beast with a snorkel.
    Apr 2010
    slaughter, la
    59
    i don't know about a br set up like that,but a friend of mine has a stock br 250 and i walk all over him. he is running over blown 25" bear claws. height wise, his tires are the same as mine and a lot wider, being that i have skinnies all the way around. i believe the best mudder has the best torque to weight ratio. plus you really can't paddle a 250 because the way the swinger is set up
    Mar 2011
    belleview, florida
    29
    ya big red 250s are nice but i just think they would be better with a low range like the 200s have or if it was chain drive but regardless i really like my 200m i have faith in her!shes gonna do exactly what i need her to so im excited
    Apr 2010
    slaughter, la
    59
    oh yes the m will be top notch. i love my 185. the only thing i would like to have is one-eletric start which you have. the other is reverse which is nice when you bike decides to go sideways. and that is why i want to get my 200 es going. but i have to quit spending money on the 185 and the wife and kids bikes.lol
