So I went trail riding two weeks ago and broke my fender almost all the way across. Since I didn't really see a fender on ebay that I wanted to buy, I decided to fix the one I broke just to see how it would turn out. I took a solder iron and melted the plastic together on the top. Then I took 3 zip ties to help support the weight on the top part of the fender. (I painted the zip ties red with some extra paint I had.) Then to help support the bottom, I cut a couple zip ties into about 1 inch pieces and glued them across the crack using some E6000 glue. It feels really strong. I accidentally bumped into the fender pretty hard and I didn't hear any cracking sounds. Here are some pictures of how it turned out. It needs a little sanding, but from a distance, you can hardly tell there was a crack. What do you all think?
