Results 1 to 15 of 16
Thread: flat tracking tires
    eddie pettengil is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2007
    nh
    297
    flat tracking tires
    my local track up here in NH will let me run with them. its a 1/5 mile high bank clay oval. i run a 250r (86) all set up for ice racing. i have a 10 inch front wheel also. what tires and size would you guys suggest running (hoosier,american racer)?
    jrsqlc's Avatar
    jrsqlc is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Northwest O HI O
    321
    I run Maxis orange label on our oval...1/5 not much bank tho
    brd812's Avatar
    brd812 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Roaming Shores, Ohio, United States
    238
    are you running with quads or trike only class? both are set ups or way different. If you want to just dabble in it Duro makes some good cheap tires to try it out first before you commit big money. I can give you specs. on what we did with our Tecates back when we ran trikes. Gearing and supension are way more important than tires to start. We ran Carlilse(sp) R/A to start with and they were no more than grooved garden tractor tires.
    "If you are going to piss like puppy, Don't Get Off The Porch"
    Trikes:
    84' Suzuki ALT185 (old Orange)
    85' Yamaha 225DX, piped and spaced ( First Girlfriend)
    Quads
    87' Yamaha Banshee, built and very very fast (The Whore)
    01 Yamaha Raptor 660, built and piped (The Beast)
    03 Suzuki Vinson, 26's and piped (The Crowd Pleaser)
    Once apon a time:
    85' Tecate 300 alky flattacker, 6 in over swingarm, 88 Suzuki 500"Quadzilla"PIA , 91 Yamaha Warrior Built and Modded. (luved that Baby Tank)
    Fresno Ca
    2,695
    Hoosier, Only way to go.
    Feb 2007
    nh
    297
    I think im going with the maxxis orange (ebay $140 new). What size do u think 18x10x10 or 18x8.5x10? Will the blue label wheels work or should I go red.
    The hoosiers are way to much $.
    I heard the duro's were not very good at this track.
    I think i will most likely be running in the quad class unless we get enough trikes. Im good with the setup stuff, its a 310 flattracker r i have been ice racing with for 6 years.
    Pic of trike.
    http://nh-meatviceracing.webs.com/ap...toid=118374960
    here is a vid of the track (not trike related).
    plymouth,il
    1,231
    that red 400ex is rippin it up
    Life is better on 3 wheels
    1984 200es big red
    1976 suzuki rm125
    1983 honda 250r (minty fresh) SOLD
    1986 honda 350x (A PILE....for now)
    197? honda 90 (pauter framed little beast in the making)
    The Open Road
    4,727
    No....on the Blue Labels
    some tires no matter how careful you are or what new kind of ATV tire machine they use will bend them up installing tires....blue labels are WAY thin...I`ve bent three or four real easy....get the red at least...I`ve bent a blue label just by ing into another guys wheels on the track and they bent like a pretzel....gocart wheels really
    sbjones73's Avatar
    sbjones73 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    wisconsin
    414
    man i wish they would let us run trikes on flat track here in wi. i would be all over that !!!!!!
    keep us updated with vids !!!
    84 250r gone,
    87 suzuki lt250r trail machine, gone to fund ice racer,
    85 250r ice racing project started !!!!!!
    brd812's Avatar
    238
    18x10x10 w/ offset blue labels would be the ticket. (stay off the walls though) what gear do you run on ice? we played with our gearing alot, depending on moisture and tire presure 2-4pounds on the left and 3 to 6 on the right.
    Trikes:
    Quads
    Once apon a time:
    poohbee1's Avatar
    poohbee1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2010
    terre haute indiana
    404
    im not a flat tracker i only did it once but i would bet the 8.5 wide would be alot better on a three wheeler than the 10 wide i would think your going to have to do alot more sliding than those guys on the four wheelers they look like there on rails. looks like you could run a pretty soft compound on that track without burning them up. nice wheeler
    Terryville,CT
    1,616
    Eddie i will be joining you for sure for a race or two at good ol Rocky Roger! lol i would be looking for a set of 16x10x8 no sidewall flex at all!
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    poohbee1's Avatar
    Apr 2010
    terre haute indiana
    404
    If you are still looking for a short track tank you can still get them from honda .About 190$ at service honda i put a picture of the part number up for you in case you need it they only come in black.
    brd812's Avatar
    238
    nice video... brings back good times. a slamed 4 stroke will be hard to beat even with your 310 kit. Like the other poster said " like rails", we had a guy w/a TC Racing 350x that we couldn't touch. The dang thing made so much torque out of the corners it would take us whole straightaway to run him back down. Mind you it wasn't close to stock and had the largest Lectron carb I've ever seen and we had no idea what Tom Carlson had done to the top half other than it went thru alot of alcohol. Looks to me your gonna need wheel speed and harder tire to run with the quads. They can run the softer compounds and not worry about highsiding in corners as much. You have a great looking R, I'm sure you will represent it well. I'll scan some of my old pics of My 85 Tecate all slamed and struted how we ran. It was a 300 with TDR reeds and Lectron carb, PSI pipe, 6in over swinger and RPM 4+axle,w/lead down the front down tubes. Nothing beats the smell of alcohol burnin strokes on a Saturday night, well one thing...Hope it helps
    Trikes:
    Quads
    Once apon a time:
    Feb 2007
    nh
    297
    brd812- On the ice this year I had my best luck with 15x38 gearing. We raced on a 1/5 mile track like in the video but it was more rounded with longer corners and less of a straight. I had to shift into 5th in the middle of the straight and down shift to 4th going into the corners.The track in the video looks more like a paper clip shape. I played with gearing alot also for soft and hard ice (every option in the 14-15x36-38-39) I actually found something by mistake with my tire pressure,Left 14lb and right 8lb (i know, totally backwards) my forward bite coming off the turn was perfect but my entry getting in sucked. The racer in the vid running second with the blue 400 is more like a 460. I run with him on the ice side by side all day but the dirt might be different. I'm sure its a different feeling.
    Poohbee1- After talking to some of the guys that race there and with me on the ice I decided to do the 18x8x10. I complaine about to much grip all winter so they said try the narrow tires. I really want a short track tank, was hoping for red but it might look pretty badazz with complete black plastic (i need new plastic anyways). What did you do for the mounts for the top of the shrouds.
    tri-z ripper- come on up. My website about flat tracking in ME and NH. We have a forum there for info and lots of pics & vids from the winter. http://nh-meatviceracing.webs.com . You should join. We have a schedule going up soon and point standings already started. I plan on doing a 8 race schedule for point standings ( 3 ice racing events and 5 races at jolly). Not even once a month.
    here is one of my favorite pics. wish it was closer. http://nh-meatviceracing.webs.com/ap...toid=118409139
    May 2007
    Orange County, NY !
    1,672
    Quote Originally Posted by eddie pettengil View Post
    I found that a year ago too. What's happening is you are making less screws have contact with the ice on the inside tire, and that helps you get it sideways. hurts you when braking though, because the trike wants to turn the other way. You wind up braking early, and then power on through the whole turn. I had problems with the quads out braking me, they got that extra wheel to lean on going in.
    Where in NH are you, would love to come up sometime and race with you on the ice. Wouldn't mind giving that flat track a try too.
