just wondering what every1 was runing for tire presure on stock 250es tires. it says 2.2 lb's, it just seems alittle low...
2011 canam commander xt1000 (yellow) extreme frt bumper, headlight gaurds, heated ridin gear on t-stat
87 trx250r all original
86 200x (complete restore)
2009 jeep wrangler rubicon
Surprised at no responses.
Depends on tire type and load weight etc.
I load my trike, rock it side to side and look for sidewall flex.
Sometimes 3 psi is enough and sometimes 4.5psi is what I need to keep from rolling (sideways) but I use mine for utility work.
Flying around the dunes would be be a whole different set of circumstances.
i am actually surprised there's no responses!! i thought this was an easy enough ?, but i geuss its not!!!
but i realize the more weight the more air on something that low of a psi.. i wont be using it for utility work, i have the commander for that. also im talking normal trail riding at slow speeds, maybe 40-50 lbs on the back rack. bin a long time since i was around a big red & now i just got 1. when i had the utility quads i always had 5psi in them no matter what weight.just wanted to see what every1 was using, if they were actually using 2.2 or if some other psi was the magic number.. scott
For what it's worth, I don't go by pressure. Mostly because I don't have a good gauge that'll read those low pressures. I like to put the rear end up on stands, and then just measure the circumference of the tires and match them. I've got a very narrow tape measure that works really well. I'll hook the tape on a knobby on the centerline of the tire and just rotate the tire around to measure it.
Since the 250es has a full suspension I like my tires more to the 4-5psi range. Don't need the tires to be the suspension quite as much as say the 200es I used to have that had no suspension.
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
i use my foot push test, depending on the type of riding i am doing will determine the pressure so i push both tires on the back to get them clsoe as long as they push int he same with the same force it's good. the harder the ground the softer i run to a point. i will let it push in about 1.5-2" on hard but that's it. if it's soft or more mud i let it push in mo more than 1"
________________
https://www.mikesatvfix.com
very good reply's every1, i new you all hadown system!! from what i read i;ll prolly go with the 3-4 psi & see how it rides.. just seems to stear hard & buckel with 2.5 in it!! but rides smooth & ive only rode it 4 a mile!!!!!!!!!!!
wow, that sounds like little house on the prarie days!!lol ( half pint, get me that stick with the groves in it!!!!!!!!!!!!!)
What do you do with your ES???.
On my dads ES we run 3 PSI on each tire for the mud maybe even lower, on my SX with the silverbacks im running 2psi i may just go down to 1PSI due to how freaking hard those tires are lol.
87-250sx
86-300es Big Red,The Beast
85-250sx Tiny SwampThing
85-250es Big Red
84-70 ( My Sons Bike )
I like 3.5 PSI most of the time....but I find that they work better with 2.5 PSI in the snow.
