Results 1 to 10 of 10
Thread: 1985 atc 110 question,... please help!
    va. beach
    27
    I have a 85 atc 110 as you may know from previous
    threads, my problem is this, the trike idles and runs
    and revs great, and riding on a flat surface is gravy, now
    if I get on a trail, or even attempt a climb of any sort
    and I mean any load at all, the climb in mention is really
    nothing more than a slight elevation, 10 degree! It will not
    go at all, I have checked and adjusted clutch, and rebuilt carb
    With new jets, gaskets, etc,.. just under Any load it struggles
    Tremendously, even a turn from a stop it just sits. Extreme
    Power loss, compression is good, no smoke, good clutch
    Only problem I know is float valve spring, but doesn't affect
    It at all. Any suggestions are greatly appreciated, I don't
    Want to sell it yet, its a very clean, well taken care of machine.
    And yes I have correct oil in it!!
    1985 ATC 110 web cam, cobra exhaust , k&n
    1983 ATC 185S stock, k&n
    Springfield Mo
    3,309
    When you say you have checked and adjusted the clutch and that the clutch is good, are you saying that you have brand new clutch plates, friction plates, springs and that everything is adjusted per the manual?
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    va. beach
    27
    As in the bike is a 2 owner bike and adjusted correctly
    As per Honda, and simply just has no power under any
    Sort of a load, if I rev it up and dump it it will stand strait
    Up, but if your at a stop, and in full turn it just won't even
    Get past maybe, 2400 rpm, and sits, thus machine was
    Owned by a old guy whom never took it out of low range
    And used 2 to 3 times a year to get a dear home from
    Woods, the adjustment on clutch hasn't even exceeded the
    Lock nut yet, so its never been adjusted out, I checked
    It and turned counter clockwise until I felt resistance, and
    Then back in 1/4 turn and locked it in. But you can tell
    Without doubt it is a power problem, as like I said it will
    Stand strait up, and even when taking off on flat surfaces
    It doesn't slip at all but really struggles power wise to get
    Moving, like a fat kid in a 50!!
    250Eddie's Avatar
    250Eddie is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Miami,FL
    395
    sounds like something maybe wrong with the clutch, maybe a warped spring, not letting the clutch fully activate.
    87-250sx
    86-300es Big Red,The Beast
    85-250sx Tiny SwampThing
    85-250es Big Red
    84-70 ( My Sons Bike )
    Sarnia, Ontario, Canada
    3,415
    Do you have a strong spark?? An old fashion automotive spark tester will tell the KV output of your coil..insufficient spark tension at the plug will cause a lack of power off idle. I don't know how the 110 advances or retards it's spark..improper spark advance will also cause it.
    OR have you checked to see if either of the exhaust/intake valve return springs are broken. If a valve isn't closing properly you will get a similar symptom. While you are at it check the valve clearance adjustment..
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    6,811
    Sounds like the timing advancer is stuck . Pull the cdi cover off and see if the advancer moves with a little spring tension .
    va. beach
    27
    Could be timing advance, it was gone into upon replacing
    The bent exhaust valve my dealer did that operation, and
    I did notice the spark wasn't a good blue, but a yellow, and it
    Really is lacking power at take off, I will check those three things,
    And one last question, if it is weak spark, how do I correct
    That?
    3,415
    Bad coil maybe or check for problem with bad grounds to start..there are tests for voltage before and after coil. Probably can be found in manual. Do you have the link to the manual??..it's around here somewhere.
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    3,415
    Wait, what..you said a bent exhaust valve was replaced? Has this been a problem only since that repair??
    Valve timing could definitely be this issue..when the dealer replaced the valve they may have made a mistake while putting it back together.
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    va. beach
    27
    No, the power problem existed before the valve repair
    It's always had a lot of low end weakness, I'm ready to just
    Sell it!! And go bigger, I'm not expecting to haul ass on a
    110 but I do expect it to atleast move on its own power!!
    It truly feels as if I'm trying to take off on a 49cc kids bike
    On a hill just trying to move in full turn from a stop. But
    Once you get it going its fine, all the power you need, will
    Top out about 35 but getting it going is the problem!!
