When asking running questions here is a few things to consider.
What size and type of carb?
What is the pilot and main jet sizes in that carb and needle clip position?
If you are running a stock 85 carb,then IMO throw it at a stray animal that gets in your trash cans...Get a 86 carb, or even better yet a PWK 38.
Have you tested the coil?
What spark plug are you running and at what gap?
130PSI compression? TOO LOW. Start there first..Make sure you have a good compression tester.
Proudly NOT a member of
"Team on the Teat"
