here's the deal. i own a 1985 honda 250sx. the swingarm bearings went out so i started out on changing them. while in the process of removing the driveshaft i removed the output shaft from the engine also. when i did so you could look into the block and see the gears just loosely sitting there. now im usually a decent shadetree but i think i screwed up bad here. i guess that will happen from time to time. any advice on how to install my output shaft or if i even can without dis-assembling the engine. any and all advice is very apreciated
