Results 1 to 15 of 66
Thread: Most frustrating thing u have ever done?
    Central illionois
    164
    I tried for 4 hours to get a set of bearings out of the rear end of my r, so wats the most frustrating thing you have done?
    OK
    5,450
    Replacing the clutch on a Ford Ranger pickup (the slave cylinder is inside the bellhousing), and that 250R right hand hub bolt I fought for 2 weeks..
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Central illionois
    164
    Ya and once after riding for 6 hrs of hot humid woods riding my 350x would start, o ya I had falling in a creek too
    Southern MN
    1,875
    Siezed swingarm bolt - on an 84 250R that was blown up, partialy parted out, and left outside for 15 years in the weather to die. That is the R that I bought. That swingarm bolt was a real biotch. I used heat, penetrating oil, and a real big railroad track sledge , 25lbs plus easy. After at least 100 hits, it started to budge.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Apr 2002
    s.w. michigan
    6,498
    Not so much frustrating but to me, more incredible as to how many things you need to take apart and get out of the way on the P-3 (Polaris trike) to replace the starter.
    A couple of bolts are easy to get to. Then you start taking off side cases (both sides), clutchs and all sorts of unrelated stuff just to get the starter off.
    I strongly feel they built the whole machine around the starter.
    Dec 2002
    Harpursville NY
    428
    Convincing the wife to let you buy another trike.
    Im just a racing redneck.
    plymouth,il
    1,231
    Replacing my rear axle and rear end bearings in my 200es it took forever to get the axle busted loose.
    Life is better on 3 wheels
    1984 200es big red
    1976 suzuki rm125
    1983 honda 250r (minty fresh) SOLD
    1986 honda 350x (A PILE....for now)
    197? honda 90 (pauter framed little beast in the making)
    PA
    3,515
    Deal with the ex wife........
    WWW.HREATV.COM
    OK
    5,450
    Quote Originally Posted by SWIGIN View Post
    Been there done that..
    Rides:
    My feedback thread
    Blossvale NY
    4,563
    Replace tracks, drive gears, undercarriage rollers and all pins and bushings on the 6-way blade of a JD450g dozer.....LOTS of siezed bolts that broke when attempting to unscrew. LOTS of time getting to know a cutting torch, 1" rosebud and welder....not a fun job and Im glad i dont turn wrenches for a living anymore. I would gladly work on the most stubborn trike ever than do that kind of extensive work on a dozer again!
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Nov 2010
    HOLDEN,MO
    43
    talk my dad in to drive hours for anoter trike lol hes gotta love me
    Dec 2006
    St. John's Newfoundland
    1,587
    How about Change the back three plugs and wires on a Buick Rendezvou with the back plug wires stuck on. You gotta let go the dog bone top motor mounts and pull the motor forward allowing you just enough room to scrape my big hands in there. Now introduce a knife to the little space your hands take up and cut the old plug boots off and replace the plugs. I swear the motor belongs on the floor for such a job. Even a little Japanese man would find this task hard.
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    scottyms's Avatar
    scottyms is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2006
    Quote Originally Posted by Brockey View Post
    Try doing the lower intake manifold gaskets in the same machine.... i swear the devil was the man that designed that POS engine... who ever thought that it was a good idea to have the valve train pushrods go through the intake manifold should be analy probed with the pushrods from every one of those ever built.... 6 hours of taking shiz off to do a 10 min gasket change then having to reset the entire valve train and put the whole thing back together....
    scotty
    current line up:
    86 KXT250 Tecate
    87 KXT250 Tecate
    86 ATC350X
    87 ATC200X
    85 YTM200
    and about a dozen more in parts...
    Dec 2006
    1,587
    Quote Originally Posted by scottyms View Post
    scotty
    LMAO, oh my!!! I can clearly see your pain. I agree with you totally on the pos and what should be done with the designer.
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    dksix's Avatar
    dksix is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2010
    North East Tennessee, USA
    610
    Right now coating a Bultaco cylinder and head, but that's cause it what I did tonight, lol. Those are some deep cooling fins on that jug and the steel sleeve was causing the powder to back ionize, it took 2 hours to mask them and I'm working with a new system. I blew the powder back off the jug 5 times before I got the system set up to get deep into the fins.
