Results 16 to 30 of 31
Thread: fixes for slipping clutch?
    Oct 2007
    Minneapolis mn
    4,067
    Its the service category for the oil... Check this link... Gives the details
    http://www.gf-5.com/the_story/why_gf...nce-standards/
    ctbale is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    anchorage alaska
    289
    all automotive oils that are less than 10w-30 viscosity usually say "energy conserving" in the circle on the back, that means it has molybdenum disulfide, slippery stuff, bad for clutch plates, I use moble one 10w-40, trannys shift silky smooth, cluthes never slip, and its ez to find at wally world in 5qt jugs.
    osoyoos bc canada
    1,057
    i sand mine but i use 400 grit and ive tryed heating springs red hot and dipping then in used black oil it worked good once but it made it worse the last time i did it
    Mar 2007
    Texas
    5,045
    manual clutches are different than semi-auto or auto stuff. manuals have to have stuff designed for it, where auto and semi-auto can run the other stuff. I've ran pennsoil 10x40 for years in my semis and recently changed over to castrol GTX. great stuffs!!!
    ________________
    https://www.mikesatvfix.com
    Nov 2006
    southern oregon
    2,338
    Quote Originally Posted by oscarmayer View Post
    How so? .
    2-stroke lover
    osoyoos bc canada
    1,057
    they both use plates and they both react the same way to oil
    squirrel1182 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Derry, Pennsylvania
    253
    Do any of you guys use wolfs head 10-40? My good friend buys it many (10+) cases at a time and i know hell hive me a coaple quarts. Would this stuff be fine instead of motorcycle oil?
    1983 KLT 200 C
    1978? YZ 125
    1978 Panther 5000
    1939 Farmall A, 51st farmall A ever produced.
    1946 International A Industrial
    1973 Ford F100
    louisiana
    1,499
    what bike are you working on.
    Signature pic removed,becuase of no helmet.
    Oscar, where are you coming up with this crap lately?
    Derry, Pennsylvania
    253
    Quote Originally Posted by leevarnado View Post
    1983 klt 200c
    1983 KLT 200 C
    1978? YZ 125
    1978 Panther 5000
    1973 Ford F100
    Blossvale NY
    4,563
    Key info to look for on the bottle is "safe for wet clutches" or "motorcycle oil". Thats about the only way you will know if its safe for wet clutches. If you dont see anything like that on the bottle, dont use it.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Sep 2009
    Suring Wisconsin
    967
    I just saw your clutch plates on ebay the other night for $6.99 free shipping or maybe $3.99 shipping. it was an old set in a yellow package I think. I bought some stuff from the guy, cheap new old stock stuff. i do not think he had what they fit in the title only in the add. I am going to be parting one out soon but I would have to get more than that just for the used basket assy.
    dksix's Avatar
    dksix is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2010
    North East Tennessee, USA
    610
    I've had luck with blasting the steel plates and sanding (400 grit) the glaze off fiber disk as well as putting a washer under the springs. It's just a temporary fix for a permanent problem but might give you some extra time before it's completely gone. If the washers help, check into replacing the springs when you replace the disk. It's always good to support local shops but sometimes local shops sale at list price and you can get some good deals on old stock or after market brands on ebay.
    Nov 2009
    1,147
    Wolf's Head 10W40 will work fine. You can spend hours reading about wet-clutch oil vs diesel oil vs car oil and all the specs and moly, zinc, phosphorus.
    Energy Conserving Oil=Bad
    standard 10W40=good
    Diesel Oil=better
    Motorcycle wet-clutch oil=best
    But out of standard 10W40, diesel oil, and motorcycle oil, the key thing is changing it frequently.
  15. #30
    Derry, Pennsylvania
    253
    Quote Originally Posted by 200XMichigan View Post
    standard 10W40=good
    Diesel Oil=better
    Diesel oil? heck my friends dad buys that 15 gallons every time hes gotta change oil in his rig and he only uses like 13 gallons, Ill try that once mom picks me up a filter.
    1983 KLT 200 C
    1978? YZ 125
    1978 Panther 5000
    1973 Ford F100
