Results 1 to 15 of 15
Thread: xr200 cam Q
    pcs's Avatar
    pcs is offline Just Too Addicted Arm chair racerJust too addicted
    Jan 2011
    yuma, az
    465
    xr200 cam Q
    so im looking to get a xr cam for my 200x and ive read that the 84-85s came with a 4v head so that will definitely not work but ive seen 2 different cams for the 2v motors. some cams have the long "nose" on the cdi side of the cam, similar to the stock 200x cam, and others do not and have a flat end on the cdi side of the cam. can these cams be swapped or do they have different cdi set ups?
    Team Blue: 85 Tri-z 250: under the knife
    Team Red: 87 Trx250r 01Cr80 15 CBR600RR
    Team Yellow: 06 Ltr450 11 Hayabusa
    louisiana
    1,499
    all xr200/xr200r cams will work,except the 84-85.can you post pics of what you are talking about.
    XR185 A (79) MOTORCYCLE, JPN, VIN# ME02-5000061
    XR200 A (80) MOTORCYCLE, JPN, VIN# ME02-5100012 TO ME02-5107049
    XR200 A (81) MOTORCYCLE, JPN, VIN# JH2ME020-BK200001 TO JH2ME020-BK202164
    XR200 A (82) MOTORCYCLE, JPN, VIN# JH2ME020-CK300004 TO JH2ME020-CK303395
    XR200 A (83) MOTORCYCLE, JPN, VIN# JH2ME020-DK400001 TO JH2ME020-DK402563
    XR200R A (00) MOTORCYCLE, JPN, VIN# JH2ME050-YK400001
    XR200R A (01) MOTORCYCLE, JPN, VIN# JH2ME050-1K500001
    XR200R A (02) MOTORCYCLE, JPN, VIN# JH2ME050-2K600001
    XR200R A (81) MOTORCYCLE, JPN, VIN# JH2ME040-BK000037 TO JH2ME040-BK004171
    XR200R A (82) MOTORCYCLE, JPN, VIN# JH2ME040-CK100001 TO JH2ME040-CK110976
    XR200R A (83) MOTORCYCLE, JPN, VIN# JH2ME040-DK200001
    XR200R A (86) MOTORCYCLE, JPN, VIN# JH2ME050-GK200001 TO JH2ME050-GK204506
    XR200R A (87) MOTORCYCLE, JPN, VIN# JH2ME050-HK300001 TO JH2ME050-HK304262
    XR200R A (88) MOTORCYCLE, JPN, VIN# JH2ME050-JK400001 TO JH2ME050-JK402224
    XR200R A (90) MOTORCYCLE, JPN, VIN# JH2ME050-LK500001 TO JH2ME050-LK504990
    XR200R A (91) MOTORCYCLE, JPN, VIN# JH2ME050-MK600001
    XR200R A (93) MOTORCYCLE, JPN, VIN# JH2ME050-PK700001
    XR200R A (94) MOTORCYCLE, JPN, VIN# JH2ME050-RK800001 TO JH2ME050-RK803024
    XR200R A (95) MOTORCYCLE, JPN, VIN# JH2ME050-SK900001 TO JH2ME050-SK902529
    XR200R A (96) MOTORCYCLE, JPN, VIN# JH2ME050-TK000001 TO JH2ME050-TK003529
    XR200R A (97) MOTORCYCLE, JPN, VIN# JH2ME050-VK100001
    XR200R A (98) MOTORCYCLE, JPN, VIN# JH2ME050-WK200001
    XR200R A (99) MOTORCYCLE, JPN, VIN# JH2ME050-XK300001
    XR200R AC (00) MOTORCYCLE, JPN, VIN# JH2ME051-YK200001
    XR200R AC (01) MOTORCYCLE, JPN, VIN# JH2ME051-1K300001
    XR200R AC (02) MOTORCYCLE, JPN, VIN# JH2ME051-2K400001
    XR200R AC (98) MOTORCYCLE, JPN, VIN# JH2ME051-WK000001
    XR200R AC (99) MOTORCYCLE, JPN, VIN# JH2ME051-XK100001
    Signature pic removed,becuase of no helmet.
    pcs's Avatar
    Jan 2011
    yuma, az
    465
    http://www.bikebandit.com/houseofmot...1946#sch613081
    part number 2 "short" cam?
    http://www.bikebandit.com/houseofmot...9703#sch423644
    part number 3 "long" cam?
    im sure these are the correct names but im just describing the cam. everything else around the cams looks the same
    louisiana
    1,499
    those are the same cams,i dont know why one shaft looks shorter but they are the same.honda only sells one cam now for the 185/200 model bikes.
    Wichita, Kansas
    1,359
    What about the cams for a 85 200m? What cam can i replace that with?
    louisiana
    1,499
    the one cam honda still makes for the honda atc 185/200 is also the same cam as the one for the xr200.honda no longer makes the cam in diff specs,they only offer it in the xr200 spec range.
    pcs's Avatar
    Jan 2011
    yuma, az
    465
    i looked at the part number and they are the same but ive seen some xr200 cams on ebay that look like the "short" version from the pic on bikebandit and some that look longer. ill look on flea bay and post the link if i find one.
    louisiana
    1,499
    that has me puzzled also,maybe need to ask someone with a little more knowledge than i about that.
    pcs's Avatar
    Jan 2011
    yuma, az
    465
    true, because from what i read on the forum, all xr200 cams fit except the 4v head. i looked at the rest of the parts on diagram from bike bandit and they all look the same so i dont know why the front of the cam would be different. wonder if someone else can chime in with more knowledge on the subject so we can inform forum members that is possible not all 2v xr200 cams swap in to a 200x atc.
    pcs's Avatar
    Jan 2011
    yuma, az
    465
    so i got a brand new xr 200 cam. it fits inside the head and the cam gear bolt up and the look the same except the front is shorter but everything else fits up. i also took some measurements and feel free to correct me if im wrong
    cam lift can be measured by the largest point on a cam minus the smallest point in inches then mult by 1.8 = lift
    the cam i pulled out of my 200x measured 1.28125"-1.03125"= .25" x 1.8 = .450" lift
    the xr 200 cam measured 1.250"- 1.03125= 0.21875 x 1.8= .39375" lift
    i didnt measure duration of the cams but the mystery continues, im just going to sell the xr cam, its brand new and cam in a genuine honda parts box if anyone wants it. ill post pics tomorrow. im guessing that the previous owner might have already put a hi perf cam and didnt tell me.
    Nov 2009
    Okauchee, WI
    555
    Pcs, I'm kinda in the same boat as you. Got a couple cams, one supposedly stock 200x and one supposedly xr200 cam. Been tryin to find out how to determine which cam is which. I measured both cams according to your post above. Both cams measure 1.276" for the high side and 1.026" on the low side. Do the math and the both come out to .450". So both cams would be higher lift than a xr200 cam, right? I assume in my 200x engine right now I have a stock cam. Guess I'll pull that cam out and measure it the same way to see what it is.
    '85 Honda 200X
    '85 Honda Big Red 250es
    '85 Honda 250R
    '82 Honda ATC 70
    '87 LT500R Quadzilla
    BRUP!!!!!!!!
    S. Florida
    26
    a 200x cam with that much lift (.450) is the most radical, highest lift cam made for the 200x... really designed for all-out race motors only. .393 is also a high lift cam. You may may want to check your measurement method. the stock 200x cam is somewhere around .260-.280" lift. I guess it is possible that is the cam in your motor providing a previous owner did some work to it.
    pcs's Avatar
    Jan 2011
    yuma, az
    465
    my first clue should have been this, i bough a complete Ti valve spring kit from R&D valve springs and measured the valve spring pressure at 75lbs, the stocks ones i pulled out had 98lbs... i got the atc from the original owners son and every other atc he has are built up, drag ports, pipes, extended swingers, so it wouldnt surprise me if he did some work to this one too.
    i agree that i my measurement might not be 100% but the cam that is in the motor is larger than the xr cam and if i compare the xr cam specs i measured with web cams specs it has a bit more lift than their torque cam for all around power that can use stock valve train parts so that xr cam i have should be larger stock.
    The Open Road
    4,727
    I believe that a cam with that much lift (.450) has to have the oil valley in the head beneath the camshaft milled out to clear the cam lobes
    .450 lift is a hi-comp, race only grind which would require stiffer springs to eliminate valve float, a hi-comp (12:1) piston...Web only goes up to a .435 IN on their full race offering
    louisiana
    1,499
    most aftermarket cams will have whoever made it engraved on it somewhere.example,webcams have wb
