Results 1 to 3 of 3
Thread: Pulling a bearing and seal out of a clutch cover. YTM225DX Help!
    Jan 2011
    earth
    57
    I am trying to get the bearing and seal out of the clutch cover on my 225dx. It is the bearing for the primary clutch shaft. The local yamaha dealer wants $75 for labor to do it. I am committed to removing it since I already tried to remove it and ruined the seal behind the bearing.
    I think I will try it first. I have a heat gun so I'm going to heat it up really hot. Does anyone have any recommendations on tools to get behind the bearing and pull it out while it is hot?
    When putting it back in I plan on heating the case and freezing the bearing. Do you guys think I'm wasting my time? This bike has become a money pit. I wish I wasn't so addicted to 3 wheelers. Best feeling in the world though.
    Thanks everyone!
    Cave Rider's Avatar
    Cave Rider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Howes Cave NY
    320
    I would try heating it first,and swiftly hit the case downwards against a WOODEN bench top..this has work for me in the past. Make sure the surface your using is soft as to NOT damage the case..good luck
    NICE QUAD !! WHY THE EXTRA WHEEL ???
    louisiana
    1,499
    if you heat the case and try to stick a frozen bearing in there,outcome prob wont be good.just trying freezing the bearing,it should shrink enough.as for a bearing puller,you can get one from autozone,they prob have a loan a tool one available
    Signature pic removed,becuase of no helmet.
