Results 1 to 15 of 21
Thread: 250r motor in the oven?
    Mar 2011
    central oregon
    81
    So.....i cut plates (with plasma table) to cover my intake and exhaust and put my motor in the blast tank, done with no problems. Now I plan on coating the motor with VHT engine paint. I have baked the rest of the parts already and wanna cure (bake) the motor......
    Bake temp. says 200 deg. For 1 hour....now for the ? Will it hurt my motor??????
    Casey
    Terryville,CT
    1,616
    shouldn't as powder coating does the same process
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    Mar 2011
    central oregon
    81
    Thanks bro....will post pics. Later this week.
    Aug 2005
    Lockport, NY
    2,395
    Ummmmm is the motor assembled still? Your seals and orings will not likely fair to well if so.
    Dec 2005
    Wisconsin
    1,141
    200 degrees F is no problem for seals and o-rings. Water temp's run at 195 Deg. F and go up past 210 degrees, that doesn't effect seals and O-rings.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    I don't care what temp they run at, I'm siding with Jeff. If it's all together I wouldn't do it. We don't do it with powder coating for even 20 minutes and I've melted silicone plugs at that temp.
    Is it a radiant oven? Is it huge? your bottom end will be right above the element that reaches well above 200 degrees to keep the entire space inside the oven 200 degrees.
    Just my thoughts...........
    dksix's Avatar
    dksix is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2010
    North East Tennessee, USA
    610
    I would worry more about the different expansion rates of the different steels and aluminum. I don't know what it will do but aluminum grows allot more than steel and the larger places in the cases that hold the bearings will grow more than the bearings. 200* isn't allot more heat than is in the engine when running but with not being able to see the effects after it's heated you won't know until you running it if it hurt anything. I doubt it will hurt anything but it would still worry me to do it.
    Walkerallen's Avatar
    Walkerallen is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Wright City,MO
    313
    i would have to agree with dirtcrasher. the engine my heat up to 210* but its not practical for it to stay at that constant temperature for that long with no cooling system/air
    1985 Yamaha 225DX-Sold
    1985 Yamaha YTM200n
    1982 Honda ATC110-Sold
    1993 Honda XR100-Sold
    1970 Honda Z50
    "If we didn't do anything we wouldn't be anyone.". Rob Dyrdek
    Quote Originally Posted by x200x View Post
    gee, a 3 wheeler worth 4000... is there something i dont know??? i mean maybe if it is straight out of a warehouse and chuck norris and mr T took part ownership in it... that guy either got RIPPED OFF or is makin 4000 up to make some other tard buy it DUMASS!!!
    Aug 2007
    Montana
    857
    You should be Ok!!!
    DO the Best With What you got !
    My Feed back :cool
    Mar 2011
    central oregon
    81
    It is an old house oven.........I think im gonna do thee 20 min session at 200 with ten min. Between each.
    Casey
    Mar 2011
    central oregon
    81
    Casey
    Nov 2002
    460
    I wouldnt recomend it , dirtcrashers right in a small oven like that you are going to get hot spots , my big powder coat oven is a convection oven so it moves air all around for an even heat , I would cure the paint with uv lights over an oven, the curing really isnt the big problem , you blasted the entire engine assembled ?? even with intake and exhaust plugged I bet you got all types of crap under the seals shift shaft, kick start etc what about the water pump vent hole, you wont beleive where that media goes what about into the stator area ?? i dont know wouldnt be my first choice
    Dec 2007
    Quebec,Canada
    1,014
    I have paint my 250r case with the VHT paint,all separate parts in an old kitchen/oven,on all the parts on the lower grill the paint was starting to burn on some spot after 30 minutes.
    I have try on other parts and 15 minutes was enought for a good job.
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Dec 2005
    Wisconsin
    1,141
    The problem with house hold oven is that there isn't enough air space to keep everything at the same temp. Remember metal conducts heat a lot better than air. If your oven temp is at 200 degrees the heating element will be much greater than 200 deg. Therefore your aluminum cases will be conducting the heat from the heating element greater than the air around it, and will be much hotter than the 200 degree air.
    1985 Honda 200x...
    Mar 2011
    central oregon
    81
    What do you think about, 20 on and 10 off. Or just open the door so that it does not cool to much or to fast.
