Results 1 to 3 of 3
Thread: no spark problem
    Jul 2003
    137
    no spark problem
    i got this 84 225dx and when i use the pull start i get a good healthy spark, but, when i use the electric start, no spark at all. it just sit's there and turns the motor, and then i can pull on the pull start and bam. so, any one have an idea?? thanks
    85 200x
    86 cr 125r..(in peices)
    85 200x..project!
    84250r is offline Clean enough to eat a potpie off of Teaching quads a lesson
    Michigan
    2,718
    Check the wiring from the starter to the spark plug area. Might have weak wiring.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Re: no spark problem
    Quote Originally Posted by groundfly
    I have seen this probably 20 times. We replaced the stator with a known good one and it fixed it every time. So my opinion is you need to find a new or good used exciter coil, you might just try to find a GOOD complete stator.
    Howdy
