I have a stock 350x, it's getting spark, fuel and has TONS of compression. It ran fine in the snow in December, but will not start. And my leg is so sore from kickin tht beast... I need help!
Have you removed your jets/petcock screens and cleaned your carb? the fuel really suks these days.........
yes, it has brand new 98 octane fuel, and i only run 98. Its 100% stock nothing ever touched... but the kill swith feels like it has some play back and forth could this be it?
not if it has spark.
Plenty of kill switches have play and you said it had spark so you tell me??
Did you even read my post???????????????????????????????
Let me be a dick again in your opinion. I'm trying to HELP YOU!
Have you taken the carb off, the petcock off and removed/cleaned all jets??
IDK WTF I bother............................................ .................................
is there gas in the bowl?, if so then i would put a drizzle in the cylinder and kick it if it fires then as DIRTCRASHER mentioned you have junk plugging up your carb and you need to properly clean it, pull it of the trike and take it apart, the new gas has a very short shelf life i am hearing as short as a few weeks before it starts gumming stuff up.
dirt gos out of his way to help and it would do you well to listen as i am told he is one overly intelligent guy lol.
ya sorry dirt crasher i did do tht! and the gas was litterlly put in 3 days ago! i am so confused about this thing not runnnin, it ran perfect for a whole year never smoked a single bit!
i did everything u said dirt crasher..
Spark at the right time, compression and fuel and it should run. I would kick it over again and again and check the plug to see if it's wet.
Everyone should run an inline fuel filter.......
Ya I know but I am so tired of kicking it I have to put all my weight intO each kick and the kicker is tearing up my boots!
have you checked your timing? my atc200 was off on timing and would not even get starter fluid to pop(it also was fine until getting put up for ~4-5 mo). also set your valve lash. both these only take about 25 min total and could get you running
also ohm out your stator to make sure your getting "good" spark, but I think it is your timing.
put some gas down the plug hole if it starts for a sec clean your carb
Not to sound like an idiot, but you do have the gas turned on right? A buddy called me a couple weeks ago cause he could not get his new atv that he bought his daughter started and i literally turned on the gas an fired right up. Just checking all the bases, not trying to piss anyone off!!
