Results 1 to 7 of 7
Thread: Before And After KLT 160 Engine Pics
    Sep 2009
    ft.worth,tx
    78
    Hey guys check out the before and after pics of my motor.I finished up on it today
    Wichita, Kansas
    1,359
    Nice work, what all did you use on it?
    franklin,, Ohio
    181
    did that charcoal color on the head and side cover come in a spray can, i love that color i want to paint my 250sx engine the same, how did you do it
    Dec 2006
    Chaple Hill, North Carolina
    198
    looks awesome!
    86 350x ( almost done)
    Sep 2009
    ft.worth,tx
    78
    Hey guys thanks for the compliments..It took a LOT of work.Here's what I did step by step.
    1 Sealed up exhaust and carb ports,covered the wires good so nothing could damage them.
    2 Sprayed the entire thing down with airplane stripper,let it sit for a bit and sprayed it off .
    3 Took my air compressor and blew it dry
    4 Double checked and taped up ALL orifices that could get anything in the engine then put it in my sandblaster and did some blasting.
    5 After blasting it I took a drill with a wire wheel and got all remaining dirt and grit off it(it pretty much polished the entire engine.I will post pics).
    6 Pulled off rocker covers and timing gear cover so I could powder coat them high gloss black.(I had already powder coated the gear shift lever)
    taped off the head and side covers to paint them with Duplicolor high heat engine enamel cast coat iron(part # DE1651).
    7 Wiped everything down that needed to be painted with degreaser and then acetone.
    8 Took my TIME and sprayed the head and side covers.They have 4 good coats on them.
    9 I then set the engine under my body shop heat lamp and positioned it to where the temp never got over 185 degrees on any part of the engine letting it sit for 15 minutes and it was done.
    10 Re-assembled it.
    The pics dont do it justice.I'm doing a lot of powder coating to a guys Banshee and he's pretty much seen the entire project and couldn't believe it's the same old motor.I was actually going to pull the engine down and powder coat everything(Like I'm doing to the rest of the tryke) but it's hard to find parts for.Plus it runs perfect so if it aint broke don't fix it right??lol
    franklin,, Ohio
    181
    thanks for the advice i look forward to seeing the rest of the pics
    Sep 2009
    ft.worth,tx
    78
    Quote Originally Posted by AtcFactoryRacer View Post
    No prob.I've been so busy working on other peoples stuff it's slowed me down on mine.lol.I'll update with more pics later.I also covered my seat(leather)
