Thread: Mechanical help 250R and YTM200
    Raleigh, nc
    71
    After a long weekend of riding it looks like I have along week of fixing ahead of me. My friend's YTM developed a loud knock in 1st gear. It is only in 1st. Any ideas on what I should look for.
    Then while riding my R it started to stutter and then cut off. I went to startt it again and it is locked solid. It was 48 degrees out and I was running 36:1 Dominator.
    Any ideas?
    84 200s
    83 250R
    84 ATC110
    85 ATC110
    84 YTM200
    85 YTM225DX
    Southern MN
    1,875
    The 250r likely siezed due to a lean condition (leaking head gasket, base gasket, intake boot or gasket, improper jetting, main jet partially clogged, flywheel side crankcase seal) are the most likely culprits. As for the ytm, check the lever, drain the oil and inspect, check the chain and sprockets, then take off the right side clutch cover, and make sure the external shift mechanism is working. If not those, you may have to split the cases, and look at the shift forks, gears, etc.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,243
    you figured it was lean from the description??? wow!!!! what color underware am i wearing?????
    ^ I heard you don't wear any..........
    I hear ya!
    Raleigh, nc
    71
    Thanks for the recommendations. I will tell you what I find when I get into them this weekend.
    84 200s
    83 250R
    84 ATC110
    85 ATC110
    84 YTM200
    85 YTM225DX
