my step bro gave up on his 185 and gave it to me but the motor is shot and i could buy motors from a 78 dr 370 , 125cc yamaha or i could mabey borrow a 07 klx 250 motor what do you guys think would be better
07 klx 250 would be whicked, but borrow???
i talked to my freind and hes dropping off the klx 250 motor tomrow he has the light and tac for it im not going to paint or clean up the trike cause the motor is brand new and it will look funny with a crap trike and kick ass motor
this motor is going to look good in the 185 the only thing i wont have is a muffler its going to be loud as f**k
and i wont have any kick start problems its got electric start
Wow - that's going to be a lot of work. Time for a Lifan/Loncin swap. Almost a bolt in.
not mine by good info and inspiration here:
http://www.3wheelerworld.com/showthr...90-lifan-200cc
I have the same engine in my 200x - I bought a $180 dirtbike with no hours (newbie owner with dirty carb) as a donor. I watch CL every day for a couple of months for a good deal.
I made my own wire harnes because my X did not have one when I got it.
I had to cut the frame crosmember under the engine to clear the drain plug.
I had to cut the sprocket cover to clear the frame.
I use the China carb with bigger jets (110/40) on the X intake with the X airbox + UNI filter and Bassani pipe.
It's OHV instead of OHC but that doesn't seem to matter beacause this engine RIPS. It will smoke my other X all day. I actually put a 13T counter (12T stock) sprocket because it runs out of gear. Very cool.
Of course if $$ is no object, bolt in a CRF 230 engine. That would be fantastic.
That seems odd to me. Is that the actual bike? How do you just borrow a motor? What happened to the Rotax?
no way will that motor fit in a 185! and even if it did - where would you mount the rads?
It all makes no sense. It would make more sense to try to turn the bike into a trike. Or something. The whole thing confuses me. Finish the Rotax 399 hardtail.
If I'm correct that's the same motor as the mojave. I was looking to do the same swap into a 200x and there's no way it would fit with out a lot of fab work to the frame. The motor is way to tall. Plus you need somewhere to put radiators. It would be a big project. If you got it done it would be quick as the klx250 has twice power.
all he has is the motor if it dont fit ill get the 370 and if that dont fit a 125 or bigger 2 stroke no mater what happens that suckers going to fly the motor was mounted in a trimoto 175 berfore untill a high speed filp killed the frame
before every one says that motor will never fit in a trimoto look at the hackjob it the background the pic is after the crash
and the rotax is still waighting for a rear end
How many bedframes will die for this conversion?
none im not cutting the frameat all i need to make front brackects and weld something up for the back
