Results 1 to 9 of 9
Thread: 45mm kiethin on an 81 250r!?!?!
    Deathrocket's Avatar
    Deathrocket is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Assachusetts!
    349
    K folks... almost got my 250r air cooled trike back together and one thing is the intake boot is torn.. I now know why.. someone managed to shoehorn a 45mm keithin on the stock intake boot. 10mm over sized sounds like WAAAAAY to big of a carb on this motor, it was running great before the piston circlip let go but still is that way too much carb?
    Mar 2007
    Texas
    5,045
    if she ran fine, runn it! get a bigger intake boot for it and have at it! on ym 200x stock had a 24mm carb, I now have a 30mm carb and it loves it! slam the throttle and hold on tight cause it's one harry ride!!
    ________________
    https://www.mikesatvfix.com
    Nov 2006
    southern oregon
    2,338
    You sure it's 45mm?
    2-stroke lover
    Assachusetts!
    349
    with my cheap chinese wanabe caliper gauge, thats what it is.... guess 44mm is as big as they go.....
    nova scotia
    125
    first gen 250r came stock with 27mm carbs
    Mar 2007
    Texas
    5,045
    you sure it's a stocker setup? maybe they ported it and used a bigger piston or higher compression one?
    ________________
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    You must be measuring on the airfilter side of the carb and not where it goes into the intake.
    May 2007
    Coshocton, Ohio
    1,815
    You are measuring the wrong part of the carb. It's hard enough to fit a 39mm carb on one. Got any pics?
    By the way, unless it's a highly modified engine, a 36mm is about all you need.
    Appalachian American Racing
    the home of
    pcs's Avatar
    pcs is offline Just Too Addicted Arm chair racerJust too addicted
    Jan 2011
    yuma, az
    465
    def would not run well with a 44mm carb, that is what zilla guys use on drag ported engine with twice the motor.
    Team Blue: 85 Tri-z 250: under the knife
    Team Red: 87 Trx250r 01Cr80 15 CBR600RR
    Team Yellow: 06 Ltr450 11 Hayabusa
