Results 1 to 10 of 10
Thread: tri z clutch kit recomendations?
    Abrams, Wisconsin
    739
    hey guys,
    shopping for a clutch kit for my tri z. i'm looking at a barnett kit and an ebc kit, both complete with friction and steel disks, and springs. within a few bucks on ebay.
    anyone recomend one brand over the other?
    thanks!
    Ontario, Canada
    48
    Hey,
    Well i can't recomend one over the other. I can say the barnett kit i installed almost two years ago now still works great! Hope that helps ya out a bit.
    1986 Tri Z (Cindy)
    1979 ATC 110
    1997 King Quad
    200xranger's Avatar
    200xranger is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2007
    St. Louis
    207
    i have a barnett in my 250r and an ebc in my tri z. i like them both. the barnett springs are noticeably stiffer. both good choices!!! hope this helps good luck.
    Three Wheels Are Better Than Four!!
    My Rides:
    85 250r atc
    85 tri z
    2012 honda rincon 680
    I will say one ,,any clutch plate with a alum backer for a friction plate,, I find contaminates the oil quicker with fine alum. shavings ,,,, even worse on a older wore out basket,, cant go wrong with OEM,Vesrah,ebc,kg factory,with a steel backer plate,altho I run barnett springs I have been shying away from the friction plates for this reason.
    Terryville,CT
    1,616
    good info Raffa, so your reffering to the Barnett frictions as causing this.
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    Ontario, Canada
    48
    Indeed, I think I might be doin a little switcharoo when I do the mains. Thanks Raffa whenever I need info on the z's I always hunt down your posts.
    1986 Tri Z (Cindy)
    1979 ATC 110
    1997 King Quad
    Yes,, thats what Im referring to.. I run belray 80w.. I ran Barnett for years,, because they had the whole kit.. with springs.. but somewhere along the line they switch to a alum backer plate.. was lookin for plates for the 490 last night ,,, and had no idea Pro-x has clutch sets,,,
    Abrams, Wisconsin
    739
    awsome info, thanks guys. looks like i'll get the ebc kit, it was a couple bucks cheaper anyways.
    Terryville,CT
    1,616
    $25. A plate for oem would have me using Barnett for a while.
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    the sport in this economy is not getting any cheeper...by all means...
