Thread: How do I change the shaft/final drive fluid on an 84 200es trike
    ontario
    143
    Looking for detailed info right down to the correct fluid. Just picked this thing up and want to change out the fluids. Thanks
    Jan 2011
    MN
    43
    There is only a little bit that goes into the final drive damper case over the shaft, all of 1.35oz. (manual specs) I would just drain the rear diff, it takes 80wt. gear oil. 11.8oz in the manual, I just did it by filling until I could put a finger in there and it touched it. Left hand side looking at the rear, big one is the filler, small at the bottom is the drain, it should be stamped on there. There will be a recess spot on the rear skid plate for the drain bolt.
    '84 Honda Big Red
    '84 Honda ATC200S
    '95 Yamaha Big Bear 350 4x4
    '01 Yamaha YZF600R
    "That's a beauty Clarke"
    http://www.3wheelerworld.com/signaturepics/sigpic22856_1.gif
    Pacific NW
    4,255
    yeah, the 84 holds like 1/2 quart 80 wt HYpoid. at least. I'd make sure of the exact amount, tho.
    now the 85+ es sx etc holds 3 point 3 ounces so like less than 1/2 a coffee cup.
    Amazing how they put up with such abuse,
    anyway
    there is an 8mm or 10mm headed bolt on the left side that looks almost
    just all the other bolts but is the drain.
    I just put my front wheel up in the truck and let it drain that way.
    10x faster and I can sorta rinse it out with the squeeze bottle of gear oil.
    Now that's on the 85 and newer models.
    oh, ok . I see yours is an 84.
    There's also an oil filter screen and a spring that should be cleaned too for the engine oil.
    Did you know there are manuals free in the world class help section?
    Welcome to the world of 3 wheeler addicts.
    Be careful, they multiply.
    Winnipeg
    211
