Thread: 1982 honda 110 atc
    jsmay's Avatar
    jsmay is offline Just Too Addicted Arm chair racerJust too addicted
    Jan 2005
    Hendersonville TN
    593
    1982 honda 110 atc
    ok, going to look at a 110 for the wife and in a year my oldest son to ride... the price is $400. the plastics are mint, seat is mint, both are original.. tank has a small dent or two.. and light surface rust on the inside... the only main problem is the guy says it needs a new clutch(which he has and is included). He said the motor runs mint no smoke and we can start it up and let it run, also we can pick up the rear so we can run it through the gears, said it just won't move when someone is on it cause the clutch is shot. anything i should be aware of? is it hard to do the clutch? any special tools needed? and what can i use to clean/seal the tank...
    thank you guys... I know there is a wealth of info on this site. I did try searching 110 clutch info but didn't find anything... probably my own error in search terms..
    jason
    Sarnia, Ontario, Canada
    3,415
    My 1st question is how do you smoke the clutch that badly?? Wrong oil is my guess..
    I haven't had to change one myself, but looking at the manual it seems really easy to do.
    Send me a note in email so that I can send you the .pdf on that section if you need it.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    jsmay's Avatar
    Jan 2005
    Hendersonville TN
    593
    i don't know what they did... yeah my guess would be wrong oil... the guy said it drove then just got slower and slower so they parked it..
    3,415
    Has to be 'wet clutch' oil..typically classed as ATV engine oil
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1,736
    the clutch is actually quite easy, get a manual and should be no problems
    I have seen machines clutches get so bad they aren't ride able because of the wrong oil.
    we took a yamaha warrior to the dunes and by then end of the day it wouldn't make it up any hills. thats with a manual clutch, wouldn't stall either, just turn the clutch
