I have a black and decker staple gun. but it stinks. What do you guys use to staple the cover down. Air gun? Electric stapler?
Help
thanks
Help
thanks
I've always used an air stapler.
I use a stanley.
WWW.HREATV.COM
If you want life to be easier. Use air or electric. It is well worth the money!
I've done a few with a basic mechanical one. Powershot I think its called. Not sure though. The kinda reverse type.
Air - BOSTICH, crown staples or no crown either way but need the air turned up to get into the plastic....
'WHEN IN DOUBT.........GAS IT!'
87 KXT250B2 Tecate
86 ATC250ES BIG RED
85 ATC350X
85 ATC70
'A FEW IN PARTS'
I use a mechanical one, some don't get in all the way, I just take them out and try again. Keep the gun very tight to the seat vinyl. Stretch the vinyl and check logo alignment and don't go threw the cover.
I use 1/4" staples on most of it and 5/16 or 3/8 where I fold it in the corners.
Take your time, it's worth it if you want it to look nice and don't pull too tight on the neck or it will be an inch off of the gas tank.
air stapler and a box of staples from Harbor Freight cost me $19 total and goes thru plastic or metal pans
I used a Powershot. It really helps to have something solid behind what you're stapling.
__________________
'85 ATC250R
.030 Over Wiseco
FMF Pipe/Answer silencer
36PJ Keihin
K&N
Boyesen reeds
Magura hydraulic clutch
Roost Boost
MSR bars
OMF swingarm skid
ITP Beadlocks
Three Wheelin' Since '84
When I redid the big red's seat 2 weeks or so ago, I picked up a stanley hi/lo heavy duty manual stapler. Some spots were tougher than others, but if you toss your weight into it, it'll do the job. Like Dirtcrasher, if it did't go through the first time, try 1/4 in any direction, usually takes care of it. Just a little time, patience, and a 6 pack of beer doesn't hurt either!
'84 Honda Big Red
'84 Honda ATC200S
'95 Yamaha Big Bear 350 4x4
'01 Yamaha YZF600R
"That's a beauty Clarke"
I use this one http://www.3wheelerworld.com/showthread.php?117039
Sometimes an $80 air gun and the hassel with lesser results just drives you to the best.
