Thread: 350x Cam bolts broke
    1,641
    I haven't looked at it,going by what was told.The bolts broke that hold the sprocket on the cam of 350x.What would cause this to happen?
    I imagine they loosened up and sheared off or the cam seized and they sheared off.
    You'll have to take off the valve cover and check it out.
    1,641
    If the cam seized there is probally silicone sealant somewhere correct?Whenever I have seen a cam seize the oil holes got plugged.Or is there another cause for cam seizer?
    Backwards oil filters like Roy likes to do
    Hope the valves aren't bad or the head journals junk.........
    1,641
    Could be costly.Will have to see when it arrives.Think they just bought it so it could have had a recent oil change.How long would it take for a seizure with a backwards oil filter.
