Results 1 to 7 of 7
Thread: 87 250sx kick start problem
    250Eddie's Avatar
    250Eddie is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Miami,FL
    395
    ok so my sisters 250sx at times the kick start wont grab the gear inside to start the bike and at times it does, also when u turn the bike off u can hear something inside spinning very fast then when it starts to slow down it knocks, what do u guys think it could be a bad return spring???
    87-250sx
    86-300es Big Red,The Beast
    85-250sx Tiny SwampThing
    85-250es Big Red
    84-70 ( My Sons Bike )
    You need the one way bearing located inside the centrifugal clutch. About a 65$ part and a cover gasket/seal for the kicker.
    Seems like 70% or better need them but we use electric start so much we don't know it.
    When you shut it off it should sound like it freewheels then clunks, and the kicker slips; Thats the indicator right there...........
    250Eddie's Avatar
    Miami,FL
    395
    well see thats the thing for SOME god given reason, when i kick the bike it wont engage the gears but the electric start works THEN if the electric start DONT work becuz of it being an old switch the kick start works
    87-250sx
    85-250es Big Red
    ^ Your talking about 2 different one way drive bearings, the starter has one behind the flywheel on the left side . The kicker one is where I mentioned on the right side; Thats the one you need...........
    250Eddie's Avatar
    Miami,FL
    395
    no i dont mean the bearing for the electric starter i mean it dont get power for some reason, but when the kick starter dont work it does get power.
    87-250sx
    85-250es Big Red
    ^ Battery, solenoid, ground or loose connection. Not too often the starters die, if they do the brushes are replaceable.......
    Get out your wiring diagram and start tracing power when the ES doesn't work.
    250Eddie's Avatar
    Miami,FL
    395
    i have to work thru it also its my sisters bike she wont help me work on it even tho i got 2 or 3 other bikes i gotta work on.
    87-250sx
    85-250es Big Red
