Results 1 to 10 of 10
Thread: Removing 86 250r chain rubber
    OK
    5,450
    First off, I have a manual. My guess would be that Honda was too ashamed to explain what a mess this was going to turn out to be. First off it's a Phillips head screw to remove the chain rubber at the front of the swingarm. I would think that a bad idea to begin with. Second, to put it right behind the "V" in the frame..? I mean come on.. So I put the bike up on a jack to let the rear droop, but I can't get on the screw straight and I'd hate to strip it (Why wasn't this a bolt again). I had my wife sit on the bike hoping the screw would clear the rear leg of the subframe so I could remove the screw.. not even close.
    So do I gather up a dozen or so neighbors to sit on the back of the 250R so I can get to the screw. Please don't tell me I have to pull the swingarm, or pull the shock to get to this screw head.
    Does anyone have any insight as to how to get this screw out? I've bought more new tools since I bought this 250R..
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Mar 2011
    Louisiana
    208
    I can't tell you how to get to it. Maybe go in every fast food resturant and find the perfect customer to sit on it. Hopefully some 250R guys will chime in.
    I wanted to give you other advice. Go to harbor freight tools and buy the heavy duty screw impact driver set!!! Do not attempt to use a screwdriver on a bolt that has been on there for years. It is like $6. Trust me, $6 is much better than drilling out the screw. Do it now!
    Also, might be a good idea to buy a new screw when you are done.
    squirrel1182 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Derry, Pennsylvania
    253
    Do you have one of those angled screwdrivers? One of them might get it out if its not siezed in too bad.
    1983 KLT 200 C
    1978? YZ 125
    1978 Panther 5000
    1939 Farmall A, 51st farmall A ever produced.
    1946 International A Industrial
    1973 Ford F100
    London, Ontario, Canada
    1,059
    Come on Doug why do you have to be like that.
    I've never changed one without having the swingarm off anyway so I'm only guessing but if you undid the top shock bolt would that let it drop enough to get full access ??
    At least you don't have to remove the swingarm like that other brand....
    My Rides
    -under restoration
    -Paul Turner pipe
    -+2" Westcoast
    1985 Green Tecate Sold
    My Wife's Ride
    My Kids Ride
    OK
    5,450
    I knew that was coming, Ross.. I earned it.. If it doesn't work I'll be back to and whine some more.
    Las Vegas, NV.
    2,531
    Sorry to hear about your issues you're having with this. On the bright side, Honda must have taken notice of this less than satisfactory design, because they changed it on the 88-89 TRX swingarms.
    Check it out, they ditched the phillips head screw in favor of a bolt, and they put it where you can get to it too!
    OK
    5,450
    Thanks guys.. Especially Ross. After looking at what a PITA it would be to remove the top shock bolt, I instead took the easy way out and pulled the bottom shock bolt. It drooped with way more than enough room. Got the screw out, new part, and put a brand new bolt in it.. WOOT!!
    Rides:
    My feedback thread
    So. Cal.
    62
    Top bolt off the shock should do it. I found using an impact driver takes that screw right out. I changed out my phillips head for a button head allen bolt and it works great!
    1,059
    Glad to help, If it keeps you from beating the R with a pipe I've done my job
    Ross..
    My Rides
    -under restoration
    -Paul Turner pipe
    -+2" Westcoast
    My Wife's Ride
    My Kids Ride
    An 8mm head bolt or allen would be allot easier to deal with.....
    Hey, At least it isn't one of the ones the whole damn swinger has to come off to install!
