There are a few ways you can raise that wheel a little more. I'm not sure if you can make it stiffer without swaping forks or adding springs. To raise the wheel, you can go as far as hitting the throttle and that should raise it some. If you pop the clutch, it should raise it to anywhere you may want it, and then some
