Thread: 85 250sx rear end noise
    Dec 2010
    se pa
    22
    Greetings!!
    I have a 85 250sx. The rear end is making some noise. I can see where it has been pulled apart before, and resealed on both tube ends and differential.
    The deal is that it makes a slight squeal or high pitched groan, when you push the bike back and forth slowly. It does not make any noise on a jack running in gear, just at a near rest.. It almost sounds as if the diff were dry and seems a bit stiff.. the diff oil has been changed, and there was no metal in it. I think it is emananting from the diff, and not the wheel bearings, but not 100% sure. Otherwise it runs and drives normally.
    I compared it to my other 85 which is quiet, and seems to turn more easily.
    What do you all think?. recommendations?
    Thank you!!
    Mike
    Silverado's Avatar
    Silverado is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2009
    Whitby
    331
    My sx did that before...at very very slow slow movement there was a slight squeal I would listen to it with the engine off while pushing it on the lawn. I changed the back wheel bearings and the problem disappeared. If you think your differential is dry sounding but you already put in 100cc of SAE 80 I would think it is your bearings......though someone can pipe it...what does a universal joint sound like when it is going ? Could it be that ?
    1985 250sx (Lemon)
    1985 250sx (Ruby)
    1985 250sx (Garnet)
    1985 200m (Hunter)
    Dec 2010
    se pa
    22
    Thank you. Yes, that is exactly what I'm hearing. Hopefully, when I can, I'll change them out and hope for the best!!
    Oct 2007
    Minneapolis mn
    4,067
    Maybe trying pulling the brake drum off quick, and roll it back and forth. (Quick check to make sure its nothing in there...)
    orick, california, go ahead google it, i'll wait
    48
    ^^ my uncle has that same bike and his brakes make that same noise and so do his front bearings
    no thats too cliche, oh what the hell GIT RAAAAAG!!!!
    Des Moines, IA
    1,303
    Yep, I had the same thing two years ago on my 250sx. It started off slight, and turned really nasty a while later. It was the wheel bearings.
    God knows they're not looking to make any effort to do anything, never mind move their foot to shift. If there was something that dispensed Cheetos every time they shifted that might be a different story. Welcome to America, where the biggest is best and even fat people who are too lazy to shift can climb a mountain.
