loud tick and sounds like the rings may be scraping the cylinder?
http://www.youtube.com/watch?v=odjk-Hr-A4A
well you wouldnt want that to be happening, check oil level?> LOL im not a 2 stroker im a 4stroker, apparently all 2 stroke 2fiddies make a ticking noise like a hockey card (canadian way) stuck in the spokes of your bicycle wheel..
sound's like a healthy 2-stroke to me
no thats too cliche, oh what the hell GIT RAAAAAG!!!!
The noise is probably a combination of excessive piston to cylinder clearance, and counter balancer bearing being worn out.Possible clutch basket rattle too.
Mine is about that loud, but I rebuilt the CB, and my top end is about 2 years old. My R engine has always been a noisy one. My quad and her trike are quiet, but they are low hour engines.
Proudly NOT a member of
"Team on the Teat"
My 86 rattles just like that and its gotten louder over last summer. It need a top end for sure its got 140 psi left. It needs clutch work and the motor has never been apart since new. I put on atleast 1000 miles on it since I got it last April.
]1986 ATC 330R
i just didnt know if it was something serious or do you guys think i can go this season with out a complete rebuild? ive already had the rings,gaskets, seals, everything but the actual piston and the cylinder bored
Sounds fine to me.
alright, 1 last question,i went riding for several hours the other day and when i shut off my atc to take a break a weird white smoke was coming out of my exhaust.....could it be the packing or oil that built up in the expansion chamber or silencer?
I'm sorta like you, I notice any and every little sound. And as the motor is breaking in, be it new reeds, top end, clutch, the sounds do change slightly as things break in (wear). I noticed on Billy's latest video he was leaning forward on a hill climb and his R sounded similar to yours. I have an 85' Tecate, the tick isn't as loud at idle, but sounds similar (the front part of motor) as yours at some RPM's. Mosh hit on it too an knows his stuff as well as fabiodriven. I was just sayin' my sounds similar also.
yea i pay attention to every noise ahaha im a little paranoid ive owned several 2 strokes and ive had bad luck with every one so im trying to make this motor last cause i plan on keeping my R till i cant ride anymore and then some
Without standing next to your engine it is hard to tell if it is too loud or not,as the camera really amplifies the ticking sound.
But if you feel better here is a vid of my R engine, you can hear the ticking it has.Been pounding on it hard for 2 years with no issues.
"Team on the Teat"
on idle i can definately hear the tick from a distance......even my dad noticed it and said back in the day his R didnt tick that loud
My Tecate makes that noise and most guys who are new to this stuff express concern when they aren't used to it. TecateDan rebuilt his motor from top to bottom, soup to nuts, and his motor made that noise right off the bat. I had to comfort him as well.
new problem just arose!!!!!! damnet! i was riding for a little bit and i came to a complete stop and it didnt catch any gears at all 1st 2nd 3rd 4th 5th or 6th........i walked it back to my house and let it sit for about 2 hours so i wasnt mad and i had a clear mind,i got on it it fired right up but still wouldnt catch gear at all,i put it in first clutch completely let out then it would catch after giving it gas then the higher the rpm it ouldnt catch at all....could it be the clutch or would it b the gears?
