200es wont shift
The gear shifter just hangs limp when you press down there is a tad bit of resistance but it wont engage, when you pull up its just limp. I pulled the sub transmission and replaced all the gears but it still wont shift Itll go into a semi neatual state if you put the sub transmission in between high and low. It went through all the gears fine before we got it running but me and a friend had to replace the timing chain when we cranked it the drive shaft wasnt hooked up and we let the engine idle for a while before we noticed the thing was in gear and the little output shaft was spinning. So basically its stuck in first. Could cranking it in gear without a load screw the transmission up? What could this be?
//ArrowChat Integreation Code
