I pulled the tank of my 84' tecate today to check the wiring for the lights and found a cut yellow wire from the switch, but there was some other wires poking out from something bolted inside the hole just under the top tube behind the headstock, i took it out to see what it is and it seems to be an aftermarket voltage regulator made by TYMPANIUM CORP.
It wasnt connected up just in there! i connected the yellow wire back together on the loom and fired it up and the light works fine!!!!
Shall i just bin the regulator!!! it wasnt even connected...!
on the wiring diagram theres no regulator on it!
