What is the gear ratio for the transmission on the 250SX vs 250ES. I know the 250ES has a lower first gear but by how much?
The have different ring and pinion gear ratio's... SX has a 4.96 rearend and the ES a 5.68 rear end...
From the service manuals: (sorry, the spacing in the table below won't stay right... just note that the SX is the first number, the ES is the second number)
SX ES
Primary: 2.407 2.407
1st: 3.615 4.083
2nd: 2.0 2.389
3rd: 1.40 1.609
4th: 1.069 1.179
5th: 0.848 0.906
Final: 4.969 5.684
So Primary is the same, but that's it. The rear axle ratio's are what Thorpe said above. Every gear in the trans is higher ratio on the ES (slower, more torque).
WahhLa... The answer! Thanks for filling in my missing part Wonderboy! I wasnt certain there was a difference in transmission gearing, but I guess there is!
Basically the difference in the 2 machines gear ratio is nothing. The ES has a higher ratio rear end and bigger tires..the SX a lower ratio and smaller tires. Meaning at equal engine RPM you are going the same speed of both machines.
The towing is basically the same..on both my ES & SX
Just that the ES is a larger/heavier machine and more suited for utility work.
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
