Has anybody changed the front end of a 200es big red 84 to something diff and did u have to mod anything or was it qa direct bolt on
87-250sx
86-300es Big Red,The Beast
85-250sx Tiny SwampThing
85-250es Big Red
84-70 ( My Sons Bike )
Not yet, but I just noticed one of the forks on one of mine looks bent,
or more accurately, looks like it's misaligned into the tube.
Maybe a spacer broke and fell out.
As far as whatever else will fit?
Wish I knew what to tell you (and myself too)
Someone will surely chime in.
i took off my shocks today becuz the axle to the front tire was locked onto the shock but i broke one free which helped in changing my front bearings but the inside are weird style springs and not oil filled shocks like the 250sx or 250es, so im hoping i can find a front end that fits and has oil filled shocks
87-250sx
85-250es Big Red
The 84 BR es I bought has an 85 front end on it. It appears that the cross bar that has the steering stops on it has been changed. It seems to work good. Go to the albums section and check out the pics.
Trikes
1970/71 US 90 (Aquarius Blue)
1972/73 US 90 Green
1982 ATC 70
1983 ATC 70 (Ladybug)
1973 ATC 70
TF 2015
Other
1983 Honda Z50
The front suspension on the front when I redid my 84 BR both were caked with mud as the boots were gone. I did replace the dampers and had the springs dipped and cleaned at a local shop and they are working just fine. Are your springs/dampers shot?
'84 Honda Big Red
'84 Honda ATC200S
'95 Yamaha Big Bear 350 4x4
'01 Yamaha YZF600R
"That's a beauty Clarke"
85 200M front end will directly swap over to the 200ES the only problem i came across was wiring for the keyed ignition dont match. I did figure out what it was though. if you search my name i have two threads i posted up about this subject. I also have pics of the whole ordeal if you want those.
R.I.P. Yamahondaman
Still practicing my NoobiX cube, take it easy on me...
1982 Yamaha YT175J ( Not much left but the's)
1982 Yamaha YT175J
1983 Yamaha YT125K + 175J =![]()
1984 ATC 200ES BR - running again - Camchain noise holding me back....
1984 ATC70 -SOLD-
coolpool does it look like they had to cut and reweld anything to fit the 85 big red front end on urs if they didnt have to that made me happy becuz i can pic up a front end from here and just throw it on.
87-250sx
85-250es Big Red
250 it does look like some mods were done. There are some welds and paint that are not factory. I'll try to get some pics this weekend if it ever stops snowing ;-(
Trikes
1972/73 US 90 Green
1982 ATC 70
1973 ATC 70
TF 2015
Other
1983 Honda Z50
Hope these pics show you something useful. Let me know if I can get something more specific.
Trikes
1972/73 US 90 Green
1982 ATC 70
1973 ATC 70
TF 2015
Other
1983 Honda Z50
hmm doesnt look like they had to cut the neck on the frame for the 200es but they had to do something on the forks for sure.
87-250sx
85-250es Big Red
The neck is stock for sure. Do those steering stops look like they are from a 200es or 250 model? Is there another angle I can try for. Also I could try washing it ;-) Had some fun yesterday!
Trikes
1972/73 US 90 Green
1982 ATC 70
1973 ATC 70
TF 2015
Other
1983 Honda Z50
hmm lemme look online see how the front forks look OEM
87-250sx
85-250es Big Red
well they did cut the OEM tree to make the 200es tree fit it so thats gonna be harder then it looks, u got something good there a strong bike with good front forks ( lucky)
87-250sx
85-250es Big Red
Maybe go with the suggestion from COX for the 85 200M coversion? That is if one is available?
Trikes
1972/73 US 90 Green
1982 ATC 70
1973 ATC 70
TF 2015
Other
1983 Honda Z50
i got a 200s sitting in the back with front shocks but the thing it that it dont have the brakcets for the front rack and headlight , what i might do is go buy a mig welder this week and weld on some brackets onto it.
87-250sx
85-250es Big Red
