Honda ATC200x piston dimensions?
Hi
I am currently building my first engine, a cb125 big bore with a 65mm bore, and i need a piston. The ATC200x piston with the flat top looks perfect but i need to get some dimensions to make sure it will work before i buy one.
So if anyone would be kind enough to measure a spare for me it would be greatly appreciated.
Mainly need the pin diameter, deck height and also the thickness of the deck in case i need to machine some height off.
Thanks Al
//ArrowChat Integreation Code
