Results 1 to 11 of 11
Thread: Cant get flywheel off honda atc 110
    Wisconsin
    Im having issued taking the flywheel of my honda atc 110 im trying to take it off so i can clean the rust off of it but when i turn the bolt it turnes the engine does anyone have an idea how to keep the flywheel stable to take the nut off thanks.
    gsw902's Avatar
    gsw902 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2009
    sanford nc
    153
    I away use an impact wrench, you will also need a flywheel puller after you get the bolt loose.
    85 atc 200s
    85 200x ( auto x project
    03 suzuki ozark 250
    swifty's Avatar
    swifty is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    sabula iowa
    381
    they make a special threaded puller just to pull it, its like $10
    ACT NOW THINK LATER!
    current trikes owned
    minty 86 250sx my rider
    pauter flat track framed 110-123cc with custom goodies
    pauter mx framed 110-123cc with aftermarket goodies
    joker framed 90-108cc with front suspension
    2007 artic cat DVX 400
    dickson sprint framed 73 green us90 with 110 engine
    Feed a rope in through the spark plug hole to hold the engine from turning. Do it when the piston is on its way up from the the bottom of its travel for the compression stroke so the valves are closed and you don't bend one. Be observant of the valves and don't blame me if you bend one.
    Mar 2011
    sw florida
    56
    take off the othe side of the case and stick a penny in there, one from before 1982. the penny is soft enough that it wont hurt any of the gears.
    Aug 2010
    St Paul, MN
    88
    I just leave the recoil catch on it, and stick a big screw driver through two of the holes. Hang on to the screw driver with one hand and your ratchet with the other. Its always worked for me!
    Oct 2007
    new york
    811
    had the same issue got a puller for $12.works on my 84 200s also.
    prairie city, Il
    15
    Iv always tapped the ratchet with a to shock it loose.
    GO FASTER DAMNIT!!!!!!!!
    Wichita, Kansas
    1,361
    I used a truck once on a poolaris 4 wheeler. Tied about 50 feet of rope to the hitch to get the angle low as possible, tied other end to the fly wheel. Me and a friend leaned the opposite way on the 4 wheeler and buddy hit the gas. It came off fast lol. HIGHLY NOT RECOMMENDED - nothing was hurt, but it could have been.
    Recommended: flywheel puller+impact; Flywheel puller + rope in plug hole on compression stroke; Flywheel puller + flywheel holder
    Puller is a must I'd say, most engine use the same threads and they are dirt cheap.
    Nov 2010
    HOLDEN,MO
    43
    i just had this problem yasterday. once i got the nut loose i took 2 handle bar clamps i think to a 200x but any will do i found longer bolts that fit into the pullstart cage on the fly wheel and loosly bolted the clamps backwords on the flywheel with out the cage on then stuck the handle of the ratchet under the clamps with the flywheel nut about half way of maybe less with the ratchet resting on the nut tighten up the 4 bolts equaly and the flywheel will pop of
    The most important part people neglect is to oil the pullers threads, it reduces the friction.
    I would buy an impact gun before I took off the side cover and needed a gasket unless you've never cleaned the oil screen and or oil filter rotor if your model has one. The rope trick works great like Fabio suggested but it must be on the compression stroke or you could get it hung up in a valve. Not for anyone who doesn't have a clear understanding of a 4 cycle engine........
