Results 1 to 8 of 8
Thread: 84 200x top end
    orick, california, go ahead google it, i'll wait
    48
    84 200x top end
    ok my first engine had a bad top end and a good bottom then i got an engine that was supposed to be a runner but the kicker gears are almost completely stripped and there is no spark but it has a brand new top end,so i was going to take the top of the new one and put on my original engine, i took the whole top end off piston and all and when i tried to put the cylinder on the piston it won't fit in this is the same piston that was in it i coated it and the cylinder with oil just like the book says but after the rings it wont go any further and i don't want to force it and scar the cylinder.
    any thoughts?
    no thats too cliche, oh what the hell GIT RAAAAAG!!!!
    Jan 2011
    Brazil, Indiana
    2,087
    you are using a piston ring compressor right?
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    chrisand4's Avatar
    chrisand4 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2008
    NC
    250
    One of the engines has probably been rebuilt, your piston might be bigger then your bore.
    Jan 2011
    Brazil, Indiana
    2,087
    he said it was the same piston and jug from one engine, just putting it on another bottom end. At least thats the way I read it.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    chrisand4's Avatar
    Jul 2008
    NC
    250
    Quote Originally Posted by hoosierlogger View Post
    Ok you're right, I read back through it.
    Mar 2007
    Texas
    5,045
    it shoudl fit, you probebly got the pisotn slightly cock-eyed and such. I like to use my fingernail and slowly go aorund each ring to compress them into the bottom of the jug taper then use my thumbs to push down ont he jugo till it touches the next ring and so on. this keeps me from damaging the rings. I tried ring compressors and have not had much luck with anything under 75mm bore it took me 4Xs longer and in the end it was in the way, so I just use my thumb nails on the ring and slightly push down as pushing the ring in. works great for me. lotta years of engine work and no failures yet, so gotta be doing soemthign right. lol
    ________________
    https://www.mikesatvfix.com
    48
    Quote Originally Posted by oscarmayer View Post
    thats how i did it and i can get all the rings in but it wont go any further
    yeah the piston matches the jug
    48
    ok the problem was the piston was a little cock eyed thanks oscar, now i just need to get the timing chain back on
