Anyone have any idea why my 200X cuts out when I'm hauling butt and hit some decent bumps? It doesn't do it on flat ground. It just kinda sputters a little then is just fine until I hit some more. Thanks.
Most likely the floats in the carb...
"Hm. Don't look too deep...Brrr....BRRRRRRRRMMMM!!....BRRRRRRUMMMM!... Never mind."
I had the same problem with the lt-160. My problem was a dirty carburetor and dirty gas tank.
Make sure you clean the inside of your gas tank, run an in-line fuel filter, replace the fuel lines, and clean/rebuild the carburetor.
My Rides:
1985 ATC 250r
1989 Suzuki LT-160
Yeah, that's kinda what I thought. Was getting some other opinions. Thanks ridered.
Will do k00leo. Thanks.
No prob. Had the same problem on a few of my rides. Usually a little cleaning/rebuild does the trick.
Their is a small plastic splash guard that goes over the main jet in the carb . See if yours is missing or broken .
mine did that too... run fine, hit a few whoops or jump and just about die. i pulled it apart and found a bunch of sediment in the carb. just get a can of gum-out.. now it runs like a scalded dog.
hey, if that doesn't do it, check for a bad ground. do not ground anything to the front end.
one cylinder is not enough!!
The little splash guard shortline is talking about is a pretty big deal for climbing and wheelies. Could be your problem, if you dont have one you should look into it either way.
