Results 1 to 9 of 9
Thread: Intermittent Spark...84 Big red 200
    Cape breton , nova scotia
    24
    hey guys , cant get my big red going after the winter... fresh gas in it right to the carb but i checked the spark and its not showing a spark every time , if i wait a few seconds it will. could my coil be shot ? , i tried another spark plug and the same thing happens...
    Miami,Fla.(305)
    808
    I got the same thing going on with my 185s. Tried, measured, swapped, & checked everything, but still happens randomly .When it does shut off,- it has little or no spark at times then after a while it starts up like nothing happened. Youre electrical stator setup is different than mine but same crap goin on -sounds like. I'm possibly gonna give those RMSTATORS a shot- I hope theyre really better than those other replacement ones. They claim high performance quality copper windings & cost a only a little bit more than the other ones & got a 1 year warranty.... If you've checked everything- else then go for replacing it.
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    NEPA
    7,051
    Go to the manuals and troubleshoot. But both SOUND like CDI box. They're fairly popular machines,if you know anyone with a good running one,switch boxes.
    250Eddie's Avatar
    250Eddie is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Miami,FL
    395
    I dont think its the CDI box becuz i was with 3wheelrider when it happened to him, thank god we had a new spark plug thats the only way we got the bike to start, which is weird that it took the plug riding thru a dry trail.
    87-250sx
    86-300es Big Red,The Beast
    85-250sx Tiny SwampThing
    85-250es Big Red
    84-70 ( My Sons Bike )
    glendive, montana
    1,822
    do a quick check on the plug to the cdi box, just a thought but if there is no dielectric grease in there and you have high humidity , it can cause funny things to happen
    Lauderdale County, Alabama
    2,029
    I just fixed a spark issue on an 84 200S today, take the cover labeled CDI off the top left of the engine, remove the two phillip head screws that you can see hold the pulse generator plate(round metal plate, magnetic) orr, and make sure the bolt is in the end of the generator shaft, if it's not, or loose, or anything, just try and pull that magnet out with you hands, if it's will slide out ANY, the small pin holding it in could have came out(very, very easy if the shaft moves), that causes the shaft not to align with the magnets correctly, and cause either no spark, or a bit of spark every now and then.
    It sounds complicated, but it's a very simple process, you'll need a ratchet with an 8mm socket, a philips head screwdriver, and if the bolt is loose, a 10mm socket.
    I tried EVERYTHING with that darn S, and I just thought about that, looked, and bingo was it's name-o.
    glendive, montana
    1,822
    I forgot about that the red dust in there can give you a hell of a time too make sure to clean and wipe all that out
    2,029
    Yeah, PB Blaster in light amounts and some cloth works great on cleaning out the pulse generator and everything.
    Wichita, Kansas
    1,361
    I had a similar issues with my KLT(gave me hell).... It ended up being a bad ground on the coil, or a slighly dead battery, or a bad plug. I fixed all them before i got a good spark lol
    I do have an RMSTATOR CDI on it. It works great.
