Results 1 to 12 of 12
Thread: fuel problem bigred
    Dec 2010
    Texas
    57
    fuel problem bigred
    I have a problem with my 85 250es. When i press the start switch or kick start the engine gas flows out the carb from the plastic line out of the float chamber. What can be causing this?
    Saskatchetoon Sk
    360
    Do you turn on the gas then try to start it??
    If so the needle and seat are stuck.
    1982 Honda ATC 200
    1984 Yamaha 225DX
    Dec 2010
    Texas
    57
    yes if i leave the gas fuel will continue coming out of the line. will i need a new carb or should i rebuilt it
    Saskatchetoon Sk
    360
    Rebuild kit will have a new needle and seat along with all the jets, gaskets, & Orings. Rebuild would do it.
    So you turn on the gas and it flows out, You turn off the gas and it stops right?
    A Cleaning might even work for you.
    1982 Honda ATC 200
    1984 Yamaha 225DX
    Dec 2010
    Texas
    57
    yes as soon as i turn off the gas it stops. thanks
    Saskatchetoon Sk
    360
    Yup 100% Needle and seat problem then. Take it apart and try cleaning it first. If that doesn't work then rebuild it.
    1982 Honda ATC 200
    1984 Yamaha 225DX
    Wichita, Kansas
    1,361
    Use a q-tip and tooth paste to 'lap' the seat. Make sure it's all nice and clean. Make sure there is a fuel filter in line. All it takes is 1 nice piece of dust or dirt to keep that needle open.
    Mar 2011
    Ohio
    236
    I've had the same problem on my 250sx. I had already rebuilt the carb and cleaned it a few times so I wanted to try all my options before taking the carb off the bike again so I took the float bowl off and the gas line off and blew compressed air through the inlet. Whatever was in there came out and it's been running great ever since. This can save you a lot of time if it works and solves your problem. If not, the other suggestions will definitely do it.
    Pacific NW
    4,255
    X2 Tipp
    Nice sx, overflowing gas, took the fuel line off, poured some mystery oil
    into the fuel line to the carb and blew it through the carb with the float drain open.
    Lucked out for sure.
    I wonder if a little spritz of carb cleaner would hurt.
    Worst case is that it has to come apart and cleaned correctly.
    Arkansas
    40
    For those of you who HAVE rebuilt, what's the kit to have? I see several options around, none of them are expensive by any stretch, I just can't tell which is the best to have for an 85 BR. I'm having the gas pouring out issue as well.
    Thanks,
    Brent
    Mar 2007
    Texas
    5,045
    get the one with the formed gasket. you do not want to fool with the unformed gasket it is a pain to make fit.
    figure on spending about $25 shipped for a nice kit. some even include different jets and such.
    ________________
    https://www.mikesatvfix.com
    Mar 2011
    Ohio
    236
    Quote Originally Posted by gostraightahead View Post
    Thanks,
    Brent
    I used the Moose kit that is all over eBay. Came with both gaskets, jets, o-rings, and the float needle. I believe it was $19 shipped.
