Yup, anything possible!
I'd just go as far and grab a motorcycle turn signal/brake light setup. Use a 35w HID head light to conserve power for the turn signals and brake light. I'm sure there are no bolt on kits for these things, just custom built.
Get the front brake perch from something that operates a brake light and is cable operated. For the rear brake, you can use a motorcycle design to turn the brake light on. Take a look at some bikes and you'll get an idea. For turn signals.. Rob a motorcycle for the electronics. You should be able to use any 12v light for the turn signals. LEDS are cheap drop ins.
