i have a 1978 Honda ATC90 and the transmission has been "sticking" like when you Upshift the shifter arm will get stuck down and then you gotta kick it back up, What could bee the problem?
also when you hold the shifter arm down it would usually put it in a "neutral" until you release it and then it would be in gear but recently it has stopped that and just automatically puts it in gear
Whats wrong with it?
