i just put on a 38mm flat slide mikuni carb and im having issues! for one it poors gas out of just about every hose as if the floats are stuck but they're not? after mid throttle it cuts out, it idles fine. its on my 85R... any ideas id appreciate..
Sounds like it might be the float height is set too high.
80' Honda CR80R
78' Honda XR75
77' Honda CT-70
74' Honda CT-70
75' Yamaha GT80 Enduro
76' Kawasaki KZ900
73' Kawasaki H1-500
76' Kawasaki H1-500
its the floats for sure! the slide wasnt closing fully but still gas POORS out non stop? this carb has individual floats and im not too familiar with this carb so im kinda confused... going from stock carb to a 38mm really has a big difference with my 310 kit thats for sure...
Sounds like your needle and seat, that is the issue probably 10 times more often than floats. If your needle/seat is dirty, it will let gas pour on through.
I cleaned everything pretty good but ill try again thanks...
Use a q tip and tooth past to "lap" the seat.
