Results 1 to 10 of 10
Thread: Ever see this happen before?
    YAMAHA_Jim's Avatar
    YAMAHA_Jim is offline 4 Motos, 3 Wheels, 2 Classes, 1st Place Arm chair racerJust too addicted
    Apr 2003
    Rock Hill,NY
    1,000
    This is a pic of the swingarm on my black blaster. I think this happened from bicycling the machine and uneven landings.I noticed it a few months ago and still ride on it almost daily.
    And also a pic of my other 2000 blaster(stock)
    Jun 2003
    Lake George, New York
    1,732
    That looks healthy jim lmao. How would a weld over that work?
    Dec 2002
    Kansas
    2,387
    look down Jim
    I had the RIGHT to remain silent, I didn't have the ability!
    Rittman, Ohio
    6,276
    Ive got one of those on my TriZ. I figured it was there to let the water drain out!
    YAMAHA_Jim's Avatar
    Apr 2003
    Rock Hill,NY
    1,000
    I thought about cutting a steel plate to cover that part of the swingarm and have it welded on.My welding skills arent the greatest. I have another swingarm ready to go on when I give the machine a makeover soon.
    TimSr-The way you ride your tri-z I cant imagine why it would be cracked there
    I'm accepting donations for the "BUY JIM A YFZ450 FOR X-MAS" fund.
    way to fix er up good
    hey tri-z jim good way to fix that up real quick for ya is just to slap so good ol duk tape on there and keep on givin er hell. spoken from a true user of the duk tape
    New Hampshire
    794
    The welded plate idea will work, provided you can penetrate into the metal enough to make the weld worth a trailprotrailprotrailprotrailpro. I would do that, then when the current arm gets more bad off swap in the new one.
    Dec 2002
    Missouri
    946
    I've seen quite a few blasters do that. Must be a problem spot for them :? But i dont care I am still gonna own a blaster one of these years!
    06 TRX450r , 85 ATC250r, 01 TRX300ex, 84 ATC110
    88 Mustang GT
    Apr 2003
    546
    the best way to fix that crack
    1) grind directly into the crack in each direction...just a little bit less than 1/8 of an inch
    2) grind your welds smooth,and paint over it with a good rust inhibitor........if you can weld at all that should be enough to hold up for a good while...however if you want more strength add a plate over that ......good luck
    1985 ATC 250R
    2006 TRX450ER
    RIDE RED...IS THERE ANYTHING ELSE??????????
    Fond Du Lac,Wi
    28
    Quote Originally Posted by md1985250r
    he's got the solution right there.thats the best way to fix a crack like that.grind into it with a dremel tool and weld over it,and grind the welds smooth....if you want,doesnt matter.But having done that before,thats the way to go.cheers to md1985
    it aint fun unless someone gets hurt.
