Ok this bike is turning into frankenstien.
Have had the long weekend off so we were riding alot. Friday 4 hours non stop, no troubles. Saturday 5 hours non stop, almost had a rear tire fall off and found out the bearings on the left side of the diff are now loose.
Today I decided to take the rear fenders off and make sure all the carb boots were tight as we were going to hit some water. The bearings are still loose so I was just going for a little ride and play in the water.
Took off and went about a 1/4 mile and had to turn around, forgot the rubbers. Raced back changed boots and headed to meet the brother in laws. Got half way back and it started to miss fire and bog when given throttle. Same problem I had before!!!
Took it back and took off the carb. Everything seems just fine so throw it back on and run it without the air box to see what is happening. Well idles just fine and when I give it throttle the damn thing backfires through the carb again. So its over fueling.
Now from what I know it could be the carb dirty again. I am going to soak it tomorrow and see what happens. Could be the intake valve as well right?
Any help would be great. I actually have a buddy that has the same problem now too so we would really like to get these things fixed
1982 Honda ATC 200
