Thread: 1983 Honda 185s cam alignment
    Nubbinz is offline At The Back Of The Pack Arm chair racerFirst time rider
    Winchester, VA
    171
    Smile 1983 Honda 185s cam alignment
    Ok, the timing is perfect on my engine, it never was off, my only question now is if it is normal for when you let go of the flywheel if the timing mark goes about 1/4 of a link past the notch ? Everything is at TDC when i hold it there, and when i let go it still is, its just that my mark goes a tiny bit past. Also is the TDC mark supposed to be only like half an inch from the Firing mark on the flywheel ? It seems kind of odd but I wouldn't be the one to know.
    Last edited by Nubbinz; 04-26-2011 at 04:30 PM. Reason: Didnt want to make yet another post
    Sep 2007
    100mi west of Chicago
    3,582
    Hey did you download the service manual from the world class help section? It has pics so you can know what you're looking for. Many times the flywheel has the T on the outside edge, so you can miss it if you don't use a flashlight
    Rob
    WilliamJ's Avatar
    WilliamJ is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2010
    Poole, England
    157
    As the chain and sprockets wear the cam timing tends to change a little. Also if the head is skimmed the cam timing will change. Anyway the manufacturer's marks are not 100% accurate, but close enough for normal use. If you want precision you have to make your own arrangements and that means verifying the TDC mark with a dial indicator on the piston top, and doing a similar thing with the camshaft. Very fiddly work and not really necessary unless you are racing and looking for the last bit of power. It doesn't sound like you want to but before you go down the route of checking all this in search of the lost power, you need to consider that with a stock cam a couple of degrees out won't make much difference. With a race cam it may but it needs a dyno to measure.
    Best thing is to check your compression to be sure your piston and rings are in good shape, check the ignition timing and valve clearances are good and do the normal service routines.
    "IF IT MOVES AND SHOULDN'T - DUCT TAPE IT. IF IT WON'T MOVE AND IT SHOULD - SPRAY WD40 ON IT!" Advice for budget racers.....I have used it myself.
    Custodian of:-
    85 Tri Z - need rear plastics to go with Mosh seat cover
    83 200x - engine being rebuilt but lodging with a friend
    85 250r - also lodging with a friend until I have a new shed
    ....and a different kind of Z
    Winchester, VA
    171
    Alright well thanks for the help I think I've got it figured out... for now.
