Thread: 200es HARD STARTING
    Apr 2009
    Saskatchewan
    119
    200es HARD STARTING
    I have a 200es that I have trouble getting started with the electric start. It will start easily with the rope but will only start with the button after the engine is completely warm. I checked my plug wire and coil and the readings are within spec it has a new spark plug and the timing is right on and the advancer is tight and operational. The carb has been cleaned recently and it has lots of compression. The battery isn't new but cranks it fast enough that it would start any of my other bikes that I have. Should I maybe be looking at changing the primary ignition coil by the stator or maybe something else. Any input would be appreciated. Thanks
    Mar 2011
    Scottsburg
    105
    Honestly I would check the battery. If it's got any age at all it could be losing charge. Mine does the same thing. Try and start it with a "hot-box" battery charger, and if it does then that's your problem. If not, then I was wasting your time and I apologize! Good luck, rugman!
    "Hm. Don't look too deep...Brrr....BRRRRRRRRMMMM!!....BRRRRRRUMMMM!... Never mind."
    Apr 2009
    Saskatchewan
    119
    What is a hot box battery charger? Is it one with a boost setting? I always thought that anything over two amps you have a real good chance of frying the cdi box. Maybe I will swap my newest battery into this bike and see what happens.
    Mar 2011
    Scottsburg
    105
    Hm...Hard for me to explain without sounding like an idiot. Some of you're older boxes will charge even while you're cranking on it, and if you turn the power up on it while you're cranking it'll crank a while longer.
    But just to be safe, I would just use a newer battery.
    plymouth,il
    1,231
    i'm also interested in finding this out my 200es is doing the same thing recently down to a T. o and a have a good battery I don't think thats the problem.
    Life is better on 3 wheels
    1984 200es big red
    1976 suzuki rm125
    1983 honda 250r (minty fresh) SOLD
    1986 honda 350x (A PILE....for now)
    197? honda 90 (pauter framed little beast in the making)
