Results 1 to 9 of 9
Thread: High compression Carb and Low compression Carb, Difference?
    Ontario, Canada
    457
    Hey, normally i'm good at figuring this kinda thing out, but i can't see why a carb would be set up differently for a high compression engine, other then jets because ya might be usen race gas.....
    what do you guys think?
    '85 ATC 250R
    FMF Fatty & Power Core
    Boyesen Rad Valve
    38 PWK A/S
    K&N w/PF (next purchase)
    LSR +4 Axcaliber axle
    LSR Duel row bearing carrier
    DuraBlue Anti-fade (to be installed)
    13/36 sprockets
    '85 ATC 250R
    Parts trike (maybe future build?)
    nova scotia
    125
    more compression = more heat so you bike will run lean if you do not jet it richer
    May 2007
    Orange County, NY !
    1,673
    Engines are air pumps. Carburetors work off the vacuum created by the "air pump". So if you change the way the air is being pumped, you might have to change the fuel/air ratio(by jetting). That's it.
    May 2007
    Orange County, NY !
    1,673
    Quote Originally Posted by barrett8 View Post
    Not true. I had to jet down. I was told because high compression engines are more efficient, they use less fuel. Not sure if that is the case universally though. Cars with higher compression engines get better gas mileage, I remember that from my hot-rodding days. Heat is not the determining factor in how lean your bike is, it is only one piece of the puzzle. Yes higher compression can generate more heat, that is why your cooling system must be up to snuff, and sometimes needs to be upgraded, but it doesn't mean you are running lean, after switching to high compression.
    Oregon
    2,471
    I like this info, when going up in compression you'll need to
    Run Race Gas.
    If you have Bought a item from me, Please leave me feedback
    If your buying a item from me check my feedback
    Click on link ~ http://www.3wheelerworld.com/showthr...ceaserthethird
    jrsqlc's Avatar
    jrsqlc is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Northwest O HI O
    321
    Quote Originally Posted by ceaserthethird View Post
    Run Race Gas.
    this is NOT necessarily true at all!! i called wiseco about my 12:1 piston for my 350X and was told NOT to run race gas.
    Oregon
    2,471
    2 strokes yes
    Ontario, Canada
    457
    interesting stuff guys!!!! thanks!!! i suspected the jetting was the only difference..... i like the high comp piston not needing race fuel for a 4 stroke, might have to investigate that!!
    '85 ATC 250R
    Boyesen Rad Valve
    38 PWK A/S
    13/36 sprockets
    '85 ATC 250R
    jrsqlc's Avatar
    Northwest O HI O
    321
    yes do investigate all you can for your model and app
