Results 1 to 9 of 9
Thread: Rear caliper question on 200x
    Wisconsin
    201
    I went to change the pads today and the bolts going through the pads busted off about an inch for the head. How in the heck would you get them out? Probably have to drill it out. I looked on ebay and they are $65 and up for one. A rebuild kit is $32. Can one get just the bolts? Hopefully I can save the caliper.
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    110 cylinder/ timing chain
    Front drum brakes
    Brush guard
    Complete rebuild to a 122cc
    Complete frame off restoration.
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    Complete rebuild to 122cc
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
    Jan 2011
    Avon, Minnesota
    641
    ya the only way is to drill a small hole with a bit then use a easyout and be carefull. Or if you can kind of grab with a visegrip try that 2
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
    3wheely's Avatar
    3wheely is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Florida
    259
    I'd try the vice grips if they're not seized up and you can get a good grip. The bolts are available. Try EBAY. I know they come with a rebuild kit and they're fairly inexpensive because I bought one.
    louisiana
    1,499
    if you have enough stud left,you can also weld another bolt,washer,or nut.really anything you can grab to try and loosening it up
    The Open Road
    4,736
    I used a FRONT caliper off an 06 CR85 on the rear I got off ebay for $26 shipped and it still had good pads....bolts right up
    "an inch for the head" whats that mean??
    The threads are in the front part, just behind the 12MM head. Some calipers have blind holes, others can be knocked out from the back; there are no threads at the back of the pad pin.........
    The Open Road
    4,736
    "an inch for the head" whats that mean??.
    It`s what I tell the ladies.......I got 5 inches plus "an inch for the head" which makes six!!! They don`t seem impressed though
    Nov 2007
    If all else fails.... do the cr 85 brake mod. Its nice
    ctbale is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    anchorage alaska
    289
    I just got a cr85 caliper for $5 off ebay, (plus $8 shipping) and the pads were new! haven't installed it, but it looks nice!
