Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Thread: Chain keeps slipping off sprocket..serious help needed.
    Mar 2004
    457
    how are the axle bearings?? i had a polaris scrambler that had a bad bearing carrier and when the axle would shift it would cause the chain to slip
    RIDE IT LIKE YOU STOLE IT! AND NEVER LOOK BACK, THEY ARE TOO FAR BEHIND TO SEE!!
    Id rather have a sister in a WHORE HOUSE than a brother in a FORD!
    1984 honda 200s's Avatar
    1984 honda 200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Calumet Island, Quebec
    446
    wha ive never had this problem before. I ride my 200s in extream conditions too. My chain comes loose i tighted it up good to go. Ive only changed the front sproket since the teeth were hardly there. Thay were so skinny LOL. the back sproket is still good and straight never replaced it yet. Ive even lost 2 bolts from the rear end- forgot to tighten them up when i first got it hahah and still chain didnt fall off.
    Your chain must be worn right out or something. From mudding all day i could see it becoming loose but that loose? ,id fix that bolt and try it again. If it does not help check for rear end play- breaings.
    Or replace chain and sprokets OR your front sproket clip is missing causing the sproket to wobble in the front?
    Maine
    18
    after reading ever ones reply, both of my 83 big reds are hardtail. there are four bolts holding the axle in place. two are stationary and the bottom two can slide in guides (not much longer then 2 in slide). i loosened the bolts and tightened the tension nut bringing the slack out of the chain to the correct slack. tightened up the rear and took her for a spin. five minutes of bouncing down the trail and running though some mud cause the chain to fall off. and wrap and jam around the main drive. no reason for this. maybe bad sprocket or bad main drive gear, or chain. axle moving is not the reason still in same position as before. still stumped on this problem.
    brd812's Avatar
    brd812 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Roaming Shores, Ohio, United States
    238
    I have a 85 ALT hardtail that many moons ago I bent the back sprocket, yeah I know I stupid and took the rear skid off...What can I say I was a teenager and it was 25+ plus years ago. If I didn't tighten it tight enough it would dump the chain until I replaced it. just a thought. i'd replace everthing, peace of mind and no cracked cases. good luck
    "If you are going to piss like puppy, Don't Get Off The Porch"
    Trikes:
    84' Suzuki ALT185 (old Orange)
    85' Yamaha 225DX, piped and spaced ( First Girlfriend)
    Quads
    87' Yamaha Banshee, built and very very fast (The Whore)
    01 Yamaha Raptor 660, built and piped (The Beast)
    03 Suzuki Vinson, 26's and piped (The Crowd Pleaser)
    Once apon a time:
    85' Tecate 300 alky flattacker, 6 in over swingarm, 88 Suzuki 500"Quadzilla"PIA , 91 Yamaha Warrior Built and Modded. (luved that Baby Tank)
    Jan 2011
    Brazil, Indiana
    2,087
    Quote Originally Posted by BigRedPudlJumpr View Post
    Can you post a picture of your sprockets? That may help us out alot. Also some pics of the rear end might not hurt either.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    NEPA
    7,049
    Whew!! You have loose axle bearings,,more than likely. Chain and sprockets need to be right,and ALL threads must be right. Then your chain will stay RIGHT where it belongs!
    Maine
    18
    pics should be up sunday evening.
    as for the bearings, there good, no sloppyness or roughness. but im doin break housing and caliper fixing so the rear axle is coming off and goin through complete inspection.
    Maine
    18
    the tension bolt on the left side rear was bent along with the guide holding in position. reason for letting the chain slip off rear sprocket.
