Results 1 to 7 of 7
Thread: Replace or rebuild the rear caliper for 200x?
    Wisconsin
    201
    I can get a rebuild kit for $32 for stock caliper. How are they to rebuild? Someone told me that they are a pain. Or I can get a cr80 caliper for $40 then no parking brake on it.
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    110 cylinder/ timing chain
    Front drum brakes
    Brush guard
    Complete rebuild to a 122cc
    Complete frame off restoration.
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    Complete rebuild to 122cc
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
    Dec 2005
    Wisconsin
    1,141
    They aren't bad to rebuild as long as they come apart. But for the 32 bux you could have a new, lighter no parking brake CR front caliper on the 200x. I'm running a CR caliper and it's good to go.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Wisconsin
    201
    I think the parking brake is great for transporting on the trailer. I'm not sure I want to get rid of it.
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    Front drum brakes
    Brush guard
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
    NEPA
    7,049
    Getting the piston back in is not fun. You can pinch your new o rings.Surgical clean!! And LOTS of brake fluid! If you do it. Very doable,but tricky the 1st time.
    Dec 2005
    Wisconsin
    1,141
    Quote Originally Posted by atc007 View Post
    http://www.amazon.com/AGS-Company-Si.../dp/B000KXJLXY
    Sil Glyde will solve all your O-Ring problems.
    1985 Honda 200x...
    Wisconsin
    201
    I ordered a cr85 caliper for now.
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    Front drum brakes
    Brush guard
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
    Manitoba
    536
    The CR caliper is a nice replacement. I don't miss the parking brake.
    84 200x
